Alternator Squeal
pickles
, Nov 13 2007 08:56 PM
10 replies to this topic
Posted 13 November 2007 - 08:56 PM
my alternator has decided to when you turn the lights on. do i need a new alternator? it is a spi and i understand they had 75amp alternators and am wondering if mine is a 45 amp?
Posted 13 November 2007 - 09:00 PM
I think they generally squeal when under too much strain or if the belt is fitted incorrectly so i'd say check that first, and if all looks fine, get a beefier alternator, or use less electrics at once
Posted 13 November 2007 - 09:05 PM
fit a new fan belt they dont cost much
Posted 13 November 2007 - 09:07 PM
looks like ill have to buy a new alternator then, but i think ill rebuild the engine first
Posted 13 November 2007 - 09:12 PM
a new belt is cheaper
Posted 13 November 2007 - 09:25 PM
yeah but im gonna rebuild my engine anyway, while its off the road, just need to build up the courage to get it out.
Posted 13 November 2007 - 09:31 PM
Seems a bit drastic when all it likely is, is the fan belt needing to be replaced. IMO etc etc
Posted 13 November 2007 - 09:35 PM
oh no! im not rebuilding the engine because of the squeal im rebuilding it because of other things.
Posted 13 November 2007 - 09:42 PM
Go buy a piggin belt.
It's either screwed, loose or about to snap.
It £2 and 20mins of your life.
Posted 13 November 2007 - 09:46 PM
i think im gonna change to a poly v belt while its out.
Posted 13 November 2007 - 11:07 PM
my 'fan belt squeal' turned out to be water pump bearings gone the way of the dinosaur or rather going, then it was 'clutch burning smell' that turned out to be water pump seals melting.. [i think]
