Bad Earth/Alternator?!
Posted 05 March 2005 - 05:34 PM
Posted 05 March 2005 - 05:42 PM
Posted 05 March 2005 - 05:52 PM
Posted 05 March 2005 - 06:21 PM
(on a side though, what a classic film!! The Money pit! Epsecially where the fire starts in the kitchen and the turkey shoots out the oven!!)
Posted 05 March 2005 - 06:26 PM
Posted 05 March 2005 - 06:43 PM
Its worthwhile checking all your wiring too, but for the light to have just come on without any other symptoms, and with the engine out only very recently built, I'd definitely say alternator.
Posted 05 March 2005 - 06:48 PM
Posted 05 March 2005 - 09:08 PM
The battery gets charged by the alternator... so if the light gets brighter when the revs are low, it means the battery isn't receiving a good charge... if the battery is 'poo', it'll be 'poo' at high revs as well as low!but your batery could be a pile of poo,
Posted 05 March 2005 - 11:02 PM
Posted 06 March 2005 - 12:18 AM
First, figure out if you need an alternator. Were you over here, I'd tell you to remove the alternator (it's easy to do) and take it to your local parts store. All the larger parts stores over here will check alternators for free using a bench tester in the store. The other way to test your charging system is to make measurements with your volt meter. With the car "off" measure the potential across the battery terminals. It should be somewhere between 12v and 13v. Have an assistant start your car and slowly increase the revs while you repeat your measurement of battery voltage. With the engine running you should measure anywhere from 1 to 1.5v MORE than the measurement you made with the engine off.
If you measure more than 14.5v the controls in the alternator are bad and you need to replace it (too much voltage and you'll boil the battery dry). Likewise, if you measure less than a 1v increase in the system voltage with the engine running, the alternator isn't putting out enough voltage (for whatever reason) to charge the battery and should be replaced.
As for the alternator ground being bad... not likely. If the alternator ground is bad, the engine ground is bad and you'd likely have trouble starting the car... or you'd be melting the control cables hooked to the engine.
Posted 06 March 2005 - 12:23 AM
Posted 06 March 2005 - 07:14 AM
A +ve flow of charge shows that the alternator is not providing sufficient current to run the car. When the engine is off, there should be no current flow, unless you have auxillary items which are permanently on. If there is then there is a drain to earth.
Posted 06 March 2005 - 10:19 AM
Posted 06 March 2005 - 12:12 PM
Posted 06 March 2005 - 03:08 PM
Succinctly, ammeters measure current (flow) of electricity. Voltmeters measure the potential (push) to move the current. Voltmeters are sometimes wired to be "on" regardless of whether the engine is running and may show battery voltage... which as stated before, should be 12-13v. An ammeter will measure "negative" amps during starting as most of the car's power is going to the starter motor. Once started, the current flow should be on the "+" side as the alternator is putting power back into the battery. The current flow (after starting) should initially be high and after perhaps 5-10 minutes of driving (not idling) the level should drop off close to 1-2 amps unless you're running headlights and other high-current drains.
Even if you meant "voltmeter" on your dash, 8-9 volts, this is not good and probably not enough to start your car. Pull the alternator and have it load tested at a shop. If it's OK have the battery load tested. Replace whichever is at fault.
