I need a bit of help!
Posted 09 March 2005 - 02:07 PM
I know they are fiberglass, but thats about all i know!
sorry i dont really help myself all that much do i?
Sian
Posted 09 March 2005 - 03:45 PM
Any chance of photo's? Where did you buy them?
Posted 09 March 2005 - 04:44 PM
Posted 09 March 2005 - 04:54 PM
You should have a rubber strip that fits between the body, and the arch, if all lines up ok, then you can drill under the lip through the arch. Then rivet..
You can use screws aswel, but i always have bad experiences with screws, so always opt for riveting!
Posted 10 March 2005 - 12:51 PM
but urm i do know that they dont have any holes in them! ull have to excuse the amount of questions im gonna ask! i have no idea what im doin!
how would i take my old arches off?
i do have a strip of rubber tho, i know that much! n then what do u mean by riveting?
sorry i understand if u want to slap me! im new to all this!!
sian
Posted 10 March 2005 - 12:56 PM
sian
Posted 10 March 2005 - 02:01 PM
get the old arches off by drilling the heads off the rivets , then they should just drop off. Just watch out if youre fitting wide arches that your mini will look silly if it doesnt have wide wheels to match - as per my mates mini im selling on the pic below! As for rivets you need a rivet gun and theyre used to hold stuff together where you only have access from one side. so poke the rivet thru the hole until the little saucer is flat on the surface of the arch, then put the long thin end into the rivet gun and squeeeze the handles of the gun together until the end snaps off, at the same time this will stick the wheel arch to the wing. Just make sure you use the right size rivet. If you dont fancy tackling it yourself im sure a garage wouldnt charge you much more than it would cost you to buy the rivet gun....
Posted 20 March 2005 - 03:46 PM
well heres my current archers.....(sorry bout the dirty state of the car jus got bac from uni not washed her yet)....
Posted 20 March 2005 - 03:47 PM
Posted 20 March 2005 - 05:22 PM
Posted 20 March 2005 - 09:43 PM
also i have already brought the white ones jus not actually put them on yet because iv neva got round it to, dont make things easy for myself do i?
sian
Posted 20 March 2005 - 10:30 PM
Use a plastic primer then spray the colour. Put the other ones on Ebay and get your money back. Only a suggestion though. :grin:
would that work? as they only appear to be plastic?
sian
Posted 20 March 2005 - 10:53 PM
good idea!! cheers!! gonna try n do that!! will giv u an update as to how its gonePut the other ones on Ebay and get your money back. Only a suggestion though. :grin:
sian
Posted 21 March 2005 - 01:33 PM
im on half term soon so if you want to drive to stafford shire and to my house then we could do them.
Posted 21 March 2005 - 01:38 PM
on a seperate subject....do many of u guys go to stanford hall?because i'm in leicester n i've got my test in 7 weeks...so i'll obviously be sorted for august!so just askin if i'd see ne of u guys there?
