i started on my door and all the paint came off with no problems at all then i moved to the a panel(this is where the probs began).
it took the black enamel off fine and some of the red topcoat (thats under the black) so i put more on and fine it took that off the red top coat and the red primer under that.
now the problem.
no matter how many times i put nitromore's on it wont touch the red that is under the red primer and the stuff that is under that.i think it has got some sort of filler primer on it and that wont move a inch.
its the same on the passenger rear to.
what can i use to get filler primer off.
cheers
edit:: pics
Edited by blue redtop, 25 November 2007 - 05:08 PM.
