Mini Roof Replaced Or Repaired
34 replies to this topic
#16 bert998
bert998
  • 2,558 posts
Posted 03 December 2007 - 04:12 PM
Aren't you supposed to brace the shell before taking the roof panel out?
:ph34r:
#17 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 03 December 2007 - 04:21 PM
what do you mean you have to say to your mini "brace your self this might hurt"
#18 Tom Booth
Tom Booth
  • 822 posts
  • Local Club: TurboMinis.co.uk
Posted 03 December 2007 - 04:23 PM
If the guter rails and pillars are there, with the glass in and doors, I should imagine the shell cant actually move that far? So its probably going to be ok :ph34r:
Edited by Tom Booth, 03 December 2007 - 04:24 PM.
#19 mk3 Cooper S
mk3 Cooper S
  • 5,569 posts
Posted 03 December 2007 - 04:51 PM
Does anyone supply roof corner repair panels for front corners?
#20 lookieuk
lookieuk
  • 257 posts
Posted 03 December 2007 - 05:04 PM
Whhhhooooo matching sunroof's ya a lukcy bugger to have one you know...lol..:ermm:
Bright red niceee... i bet that will look wicked once fitted pls post pic's when you do :ph34r:
and the roof was not supporting much at all is just basicly a tin can welding on top.
#21 Matrix
Matrix
  • 589 posts
Posted 03 December 2007 - 05:26 PM
I cheated lol
#22 jack_marshall
jack_marshall
  • 2,540 posts
Posted 03 December 2007 - 05:33 PM
:ph34r:
Dont folks worry way too much!
Cracking work mate, make sure you add up more pictures as you put it on.
Ive wondered how hard it would be to put a new roof skin on a mini...
EDIT- Just realised that mini's without roofskins look so much cooler than a mini soft top thing!!
Edited by jack_marshall, 03 December 2007 - 05:35 PM.
#23 apbellamy
apbellamy
  • 1,001 posts
Posted 05 December 2007 - 09:08 AM
I've rescently bought a '78 clubby with a vynal roof and 'some bubbling' underneath. Once I took the vynal off and had a poke, I pretty soon had about half a dozen holes. just like the yellow one above:
[attachment=45024:16102007136.jpg]
I also have a complete roof from a late car that was written off, so I think I will be fitting that and loosing the webasto. Only £30! I was going to cut that up and make repair panels, but I can't be bothered. Going to rent a spot welder to do the reattaching though, my mig would leave a real mess behind!
#24 cambiker71
cambiker71
  • 1,050 posts
  • Local Club: Cambscustomclassics.com
Posted 05 December 2007 - 10:32 AM
I've read through this post and some of the advice to not brace or support the shell whilst removing the roof is plainly wrong, the shell might not sag in the middle but it will twist very easily, if it's unsupported whilst welding the new roof back on then you could end up with a very big problem as the heat involved will distort the surrounding area, albeit very slightly, on each spot weld adding up to a possibly huge structural/alignment problem. The easiest way would be to use some sort of wooden sleeper type material under the floorpans from front to back including taking the weight of the subframes to spread the weight around the car solidly and not just at the four sprung corners where the wheels are, good luck with the project anyway.
#25 lookieuk
lookieuk
  • 257 posts
Posted 05 December 2007 - 03:27 PM
mmmmm i didnt brace my roof / car and it seems sound as a pound..ve ever been jumping around inside with
grinder cleaning up the edges...got me a littie worryed now.... :thumbsup:...well we shell see am cleaning the other roof ve got for 25 notes
so we will see plus i couldnt see how the old roof was supporting it much...its waffle thin with not much stength in it
oh and damn good point on welding but i reckon if you weld not to close to the same spot ever so offer like one there and then one on the other end of the car the heat transfer should be no problem
anyway i be posting pic's of the travel with the roof project heheh... :D
#26 skye
skye
  • 190 posts
Posted 05 December 2007 - 04:26 PM
how did you bond that carbonfibre roof pannel on?
#27 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 05 December 2007 - 04:31 PM
The roof's a compound curve, there's loads of strength in it.
#28 lookieuk
lookieuk
  • 257 posts
Posted 05 December 2007 - 05:10 PM
What even with the holes and sunroof in it...?...so have ve got summit to worry about now that i didnt brace it?
ERKKKKKKKK :thumbsup:
#29 midridge2
midridge2
  • 1,794 posts
Posted 05 December 2007 - 07:14 PM
From my experience of replacing a few mini roof skins over the years in bodyshops etc i have never found the need to brace the shell.
i am not going to start a argument off with other people about bracing the shell but base it on 35+ years repairing minis for a living as a profesional panel beater.
others may feel i am wrong but that is there choice.
this is my opinion and will differ from others.
#30 panelbeaterpeter
panelbeaterpeter
  • 5,606 posts
  • Local Club: n/a
Posted 05 December 2007 - 07:51 PM
As above, bracing is not necessary.
