Basically i have had a recurring problem regarding the front left hub, it all started back in the summer of 2007 (there was one day i recall being sunny and this was the day) *fades to dreamy scene*
There i was driving along, suddenly brakes go a bit...soft, as in the pedals doing nothing, but thats not my concern the horrible squeeling noise however is. I grind to a halt into a handy layby, as i also lost all forward and reverse drive. So what happened?
The castle nut that sits on teh drive shaft that holds the hub together and is secured with a split pit has wound all the way off the shaft, thus the drive flange (which holds the wheel and the disc brake) is allowed to move other than being inline with the brake calipers. That would explain the loss of braking power.
On top of this, the hub was allowed to move around an INCH and a half out, and so pulled the drive flange off of the shafts flanges and thanks to mr differential in the gear box, it was just spinning the left shaft freely.
We replaced the hub and bearings and split pin, and all was fine, till not very long ago, i bought a new split pin, the same thing happened some two weeks later, and now, my wheel bearings gone (in hindsight i should have changed this when the last split pin went as the odd forces excerted would have damaged then, but again, i had bigger fish to fry...).
Now ive been adivsed this problem lies with cv joint flanges and so time to replace, but being me and wanting to take no chances in something else being damaged a bought a shed load (ok it was a rather big heavy box full) of parts (and one tool) to sort this out!
Here is what arrived in the post today:
From left to right we have:
Ball joint splitter
Castle Nut
Ball joint, top and bottom, kit.
Timkin wheall bearing kit.
Left Hand side Hub
Drive Flange
CV joint (with another castle nut...above is a generous tub of grease and the CV boot and clip.)
Now buying so much allows me to pretty much build the new hub out of the car and in the warmth, so i'm rather happy in that respect i just hope it all goes to plan.
I'll keep you all informed over the day (ive got till 5pm then its work and it'll be too dark to continue outside).
Wish me luck!
