Yes i have replacement track rod ends. NEw steering arms are £25, so cutting them off will be my first port-of-call.Are you going to renew the track rod ends when you change the rack? If so then I would cut the nut off the existing ones rather than buy new steering arms. If not then remove the arms as you have now and then wind the track rod ends off the old rack and onto the new.
Your problem may be that if you have loosened the nut on the steering arm at all you have to stop the joint spinning inorder to do it back up again. Some track rod ends actually have an allen key hole in the end of the threads to allow you to hold them whilst using a spanner on the nut.
Fix My Hub, Drive Flange, Cv Joint And Wheel Bearing Day!
#16
Posted 05 December 2007 - 02:41 PM
#17
Posted 05 December 2007 - 02:49 PM
Plenty of Plus Gas on the nut religously for a few days before hand might see it come off by the normal methods though.
#18
Posted 05 December 2007 - 03:13 PM
#19
Posted 05 December 2007 - 03:25 PM
The jack under the track rod end is the usual way forward (although lifting the car sounds a little excessive, dangerous and could potentially bend the steering arm)
#20
Posted 05 December 2007 - 03:30 PM
#21
Posted 05 December 2007 - 04:48 PM
been to the auto factors and halfrauds
You should have found one at Halfords, they do sell one. It's a 1 1/2" extra deep you need, Halfords only do one as an impact socket.
When swapping the steering arms, make sure you swap the hollow dowels for the arm to the new hub. They are essential, without them you have little or no steering.
Keep going, you're doing a good job so far.
#22
Posted 05 December 2007 - 09:02 PM
What dowels sorry? Ive looked at the bits and cant make out what you mean?
Do they go underneath the steering arm? kind of slot in the top of the hub? i think they may still be on the old hub...
Also i got the top and bottom ball joints done, and the races for the bearins tapped in too
Just the CV joint swap and fitting of the bearings and put everything back together, and all should be well
#23
Posted 06 December 2007 - 08:47 PM
Reading the HBOL ( Haynes book of lies ) it said that i required an assistant to hold the Circlip on the drive shaft closed while i put on the CV joint....great i thought, cant exaclty make this friend out of wood....anyway struggle with it, pushed it in all i could all the way around, lent inward on the CV joint and it just slipped on perfect, and a lot easier than i thought, no hammer needed!
Had to rush off to uni, but when i came back my dad said he spent 2mins removing said dowel after finding all the tools around it he figured out what it was that i was doing, and just flipped the spanners over ( one side gripped the other didnt ) and pulled it straight out!
All i need to do now?
Tap up the lock tabs on the ball joints, fit the wheel bearings ( i fit the rear ones today, just need to fit the racer and the fronts ) fit the water shiled on the CV joint and put it all back together!
Hub on ball joints in, bolted up, steering arm bolted on, slide on the disc brake and drive flange, on with the caliper, brakes on to tighten up the drive flange (haven't forgotten yet) and then the castle nut, fit the split pin, wheel, nuts and rolling!
#24
Posted 07 December 2007 - 05:52 PM
#25
Posted 10 December 2007 - 08:07 PM
However what I have also noticed is that there is a difference of at least 1mm in the thickness of the nuts on either side - thats really not going to help. I will replace the passenger side nut and see if it makes sufficient difference.
For information the complete hub assemblies are new from MiniSport however I swapped the castle nuts as they came with 34mm and I wanted them to be 1 & 5/16" as they should be (one less size/spcket to worry about). So there is only the nuts that weren't brand new. Could be you had a similar 'thinner' nut causing your problem.
I don't believe the thinner nut would cause as much of an issue on twin hole CVs where they are only torqued to 150lb/ft - the torque on the single hole CVs does add a fair bit more rotation. Assuming the thread pitch is around 1.5mm (although actually it will be metric) an extra half a turn would mean the nut goes on about 3/4 of a mm further. Therefore that 1mm difference in thickness of the nut is important!
#26
Posted 10 December 2007 - 08:15 PM
Another update, i took the hub off the otherside...well, i had to take it off with the cv joint attached, the bloody bearings have mated with the cv joint!
Took some hammering to break apart there love for one another and in so damaged the threads on the cv joint, my parents have come to the rescue and have bought me a new one
Infact my dad just told me to re-order the same parts as i had for the left side ( obv with a R/h hub haha ). So ill have brand new hub assemblies, cv joints and bearings.
Lovely.
Will measure the assortment of castlenuts tomorrow, also i orderd them split washers for behind the castle nut! So everything should be ok.... just got to fit the steering rack after that.
#27
Posted 11 December 2007 - 12:36 AM
#28
Posted 11 December 2007 - 09:22 AM
Well done, hopefully not ball bearings though....
Confused me here what do you mean?
#29
Posted 11 December 2007 - 10:21 AM
