Where can i get a new heater???
I've Heard MPI units are good too? anyone got one handy i can buy?
1993 SPI 1.3 MINI
Edited by tr03bor, 13 December 2007 - 12:00 PM.
Posted 13 December 2007 - 11:47 AM
Posted 13 December 2007 - 12:39 PM
Posted 13 December 2007 - 12:43 PM
You want a MPi unit?
Expect to pay £50-100 for it then. They be silly expensive.
Posted 13 December 2007 - 01:40 PM
Posted 13 December 2007 - 01:42 PM
Posted 13 December 2007 - 01:43 PM
You know, this had me thinking - What about simply REPLACING the fan motor in a standard heater box, with a fan motor from another car (scrap yard trip) and the associated speed controls (typically 3 or 4 speeds). Most fan motors are of a similar size (just need to reuse the mini fan assembly), and all the speed control gubbins are allready there in a scrap car.........so?
Now I realize that it's not a straight forward swap, BUT should only require a small ammount of modification to the heater box, and it'll give you a stronger heater fan, which should be a lot cheaper than an MPI unit. Seem like a good idea?
I might have a trip up to the scrap yard and see if I can recover a mini heater box - plus a few parts from other cars - and see if this is doable.
SS
Edited by Mini_Magic, 13 December 2007 - 01:44 PM.
Posted 13 December 2007 - 01:48 PM
Posted 13 December 2007 - 01:53 PM
Posted 13 December 2007 - 02:13 PM
Don't you think BMW would have knicked a heater from a Rover model, like they did with the MGF steering wheel, insted of converting the normal heater to a two speed? There must be a reason why BMW couldn't just stick a Rover heater into a Mini in 1996.
Posted 13 December 2007 - 02:21 PM
Posted 13 December 2007 - 02:30 PM
I was thinking about putting a variable resistor/rheostat onto the fan so I can adjust the speed. Now it wouldn't be faster than normal but you could slow it down to just a trickle blowing on your screen like the No1 setting on modern cars.
Me being totally pap at electricsam I talking out my butt or would this be possible
Posted 13 December 2007 - 04:32 PM
Dont really want to mess about just need a new one ASAP!
Posted 13 December 2007 - 04:44 PM
Posted 13 December 2007 - 04:48 PM
Posted 13 December 2007 - 04:55 PM
