Will They Fail My Mot On These Things?
#16
Posted 16 December 2007 - 06:03 PM
The MOT manual thing s available online, is a bit of a read, but worth looking through.
The indicator light warning liights are NOT a fail unless you have a silent relay. The warning can be either audible are visual, so as long as you can hear the relay, that's cool. The only caveat iis that I'm not sure if having the lights and them nt working would be a fail. If you put some tape over the lights then you're fine.
#17
Posted 16 December 2007 - 06:05 PM
I appreciate all your advice but I'm really now more confused than I was to start with! I've been told that I need to see the lights and I've been told I don't... I've been told the CV joints will fail it and I've been told they wont... argh
#18
Posted 16 December 2007 - 06:09 PM
Chris,
May have to agree to disagree about this, the idea of having an indicator light is so that the driver know when the lights are on, just having the relay clicking may not be audible at road speeds. For part of the test the tester sits behind the wheel of the car and checks the operation of the dash lights.
Sean
Edited by shiftyseamus, 16 December 2007 - 06:12 PM.
#19
Posted 16 December 2007 - 06:11 PM
The relay is quite loud and it's under the steering column.
To put your mind at rest I will ask a mate of mine who is an MOT tester, that should help clear things up, my advice is based on what I've had minis fail on over the years!!
Sean
#20
Posted 16 December 2007 - 06:31 PM
In the long term I plan to get hi-lo's on the front and I'll get them set to a slightly higher ride height which will overcome this rubbing
Fitting hi-los is not solving the problem! The problem is old saggy suspension components. Fit new knuckles and rubber cones and this should solve it.
#21
Posted 16 December 2007 - 06:40 PM
I know I just said it'll overcome the problem
Are "trumpets" the same as knuckles or cones? Reason I ask is because I've been told one of the trumpets at the back has gone hence the sagging on one side.
#22
Posted 16 December 2007 - 06:42 PM
and you do need lights on the dash that show when your indicator lights are on.i know this as my mini failed the mot on this about 6 weeks ago.
hope that helps
#23
Posted 16 December 2007 - 06:45 PM
#24
Posted 16 December 2007 - 06:56 PM
but your missing the point that it may not be the cv joints, could just as likely wheel bearigns witch i can tell you now it will fail if it is!
He did say that it was a clicking noise on full lock which does seem to indicate CV joints.
Wheel brgs tend to be a grumble or a rumbling noise, simplest thing would be just to jack car up and check for play.
Sean
#25
Posted 16 December 2007 - 09:11 PM
cv joints wont fail a mot if they click and the gaiters are fine.
CV Joints should fail the MOT if they are EXCESSIVELY WORN OR INSECURE. The clicking noise is an indication that the joint is worn. At the end of the day it is up to the tester to decide if it is excessively worn or not.
I would suggest that an audible tell tale for the indicators would be an audible relay, similar to the noise that the you get with a tow bar installed, but it is not defined so could be a bit of a shady area with respect to a standard clicky relay.
#26
Posted 16 December 2007 - 09:43 PM
The hazard light 'tell-tale' must be a light, so while the audible relay may be ok, you will need a light for your hazard lights. If your car is pre-april 1986, then you don't need hazard lights, but if you have them they will be tested.
Personally I would get a couple of LED lights and jst fit them into your dash, couple of holes, push them, wiring's easy. Sorted.
#27
Posted 16 December 2007 - 10:15 PM
www.motuk.co.uk
My car is a 1985 but it has hazard lights as standard, they work fine.
I'm still doubtful about the view of the speedo so I've arranged to collect a new dash this week. It's the one up there ^^^ with the fixing kit included. Will save me a lot of hassle and he will customise it for my rev counter etc.
#28
Posted 16 December 2007 - 10:21 PM
What I meant was that even if the audible click is acceptable for your indicators, you have to have a warning light for your hazards anyway, so might as well use that warning light with the indicators anyway.
Sounds liek you've got it sorted anyway!
#29
Posted 30 December 2007 - 06:52 PM
So, I can see the indicator lights flashing, but they're pale orange - does that make a difference? Is it an MOT fail? Because all cars flash green as standard
#30
Posted 30 December 2007 - 07:17 PM
If you want them green, cut up a 7up or sprite bottle and stick them on the back of the dashboard. simple.
