What Security?...
21 replies to this topic
#1 Rob Himself
Rob Himself
  • 534 posts
Posted 18 December 2007 - 12:43 PM
At the moment all the Mini has is standard door locks.
I'd like central locking & immobiliser as a minimum... what else could/should I go for?
Suggestions & £££ ?
Cheers!
R
#2 stardude
stardude
  • 2,457 posts
  • Local Club: hilltop mini's
Posted 18 December 2007 - 02:17 PM
alarm? u can get very good insurance approved ones, fitted for about £300-£400
#3 Matt
Matt
  • 4,703 posts
  • Local Club: The mini forum - i live here
Posted 18 December 2007 - 02:40 PM
sticky film on the windows.. stops people being able to smash the window.
#4 mike.
mike.
  • 6,176 posts
Posted 18 December 2007 - 02:58 PM
Where can you get that sort of stuff matt?
#5 Matt
Matt
  • 4,703 posts
Posted 18 December 2007 - 03:04 PM
urrrm here..
taaada
#6 Rob.Finney
Rob.Finney
  • 88 posts
  • Local Club: Irish Mini Owners Club
Posted 18 December 2007 - 04:08 PM
do they actually work?????
#7 insamoufonyx
insamoufonyx
  • 1,633 posts
  • Local Club: NorthSomersetMiniClub.co.uk
Posted 18 December 2007 - 06:17 PM
yep it does >_< same as alot of window tints help stop windwos breaking :thumbsup:
#8 Puddings
Puddings
    Nurburgring Master
  • 1,046 posts
  • Local Club: fabmoc/TMF
Posted 18 December 2007 - 06:21 PM
But then the fire men cant smash the window to pull you out when you are knocked out and under water >_< not worth it i say
#9 redhotmini
redhotmini
  • 1,607 posts
Posted 18 December 2007 - 07:29 PM
its a catch 22 situation, do i do it for improved security, and risk being unconsious and under water? (its unlikely to happen, unless you plan a top gear style channel crossing) ive had it done on my car, and tried it out on a spare window - it will break if you use one of those special pointy glass hammers, once it tears from the pointy bit you can pull the glass out. it does stop someone putting a brick through your window, and theres a lot less mess afterwards.
#10 Rob Himself
Rob Himself
  • 534 posts
Posted 18 December 2007 - 08:29 PM
Hmm.
I'm meaning in terms of alarms ...... there's bugger all to build on, other than a simply key lock lol
#11 mike.
mike.
  • 6,176 posts
Posted 18 December 2007 - 08:42 PM
I'd start with a dis-car-nect device. They're a really clever immobiliser and dead cheap! Its basically equivilant to taking you battery with you when you park your car.
http://www.minispare....aspx?pid=36489
#12 redhotmini
redhotmini
  • 1,607 posts
Posted 18 December 2007 - 08:56 PM
they work really well, although to put most opportunist thieves off, you need something that is blatantly obvious, like a disklok that covers the entire steering wheel. ok so its bulky and gets in the way when you remove it, but its a really good deterrent. i use a pedal clamp in mine, which locks all 3 pedals together, and stops them being pushed to the floor. i like that, but its really annoying when you forget its fitted.
#13 mike.
mike.
  • 6,176 posts
Posted 18 December 2007 - 08:58 PM
Yeah i want something like that on mine - something obvious.
#14 yorkshirechris
yorkshirechris
    11.11.11
  • 3,873 posts
  • Local Club: www.lcmoc.com
The dis-car-nect would put the medicure (not opportunist but not quite made it big time - dya like my description?) thief off because he wouldn't think to look in the boot of the car when the engine don't start...
#15 redhotmini
redhotmini
  • 1,607 posts
Posted 18 December 2007 - 09:00 PM
basically, anything bright yellow, has got a lock on it is good. so an alsatian, painted bright yellow with a padlock round its neck would be ideal.
