Just been out trying to get the manifold changed over from the pervious one which was leaking from around the brake servo take off. I already had a manifold from a hiff44 which i thought would tide me over (used with my hs4) until i could properly sort it.
2 Issues came up whilst i was doing this.
Firstly, as i was unable to reuse the take-off, i have used the one built into the manifold with some 10mm rubber hosing between the manifold and plastic hose already there. Here is a pic, the question is, is the vacuum an issue in terms of making the pipe collapse or are we not taking about that much force?
Also, i cannot for the life of me get to the middle nuts on the manifold, cannot even get a single turn on them and then get the spanner out, it just isnt possible as far as i can see. Can you please help? Please don't tell me i have to grind away at the manifold.
thanks for your time
Sam
Edited by samwell, 18 December 2007 - 11:14 PM.
