is it a 12940 head? if so you can pocket the 998 and fit that then.
the car a write off or the engine?
Difference Between Lcb And Normal Maniflow
munnracing
, Dec 20 2007 12:48 PM
16 replies to this topic
#16
Posted 20 December 2007 - 09:59 PM
#17
Posted 20 December 2007 - 10:12 PM
the car is a right off unless anyone wants to try and fix it its got a damaged sill and possibility that the subframe has bent the bulkhead and all panels on front are pretty much stuffed engine ran before i took off the manifold and exhaust and carb and will be splitting it soon as need rid of it soon as its taking up spaceis it a 12940 head? if so you can pocket the 998 and fit that then.
cheers josh
