Iv got parts of a stage 1 kit including a piperx bolt on filter for my 1275.
Iv herd about upgrading the needle for the carb.
Could anyone shed me some light on if i need to upgrade this when installing the filter to make the most out of the rest of my stage 1 bits.
Bolt On Filters
shaun_89
, Dec 20 2007 06:14 PM
6 replies to this topic
Posted 20 December 2007 - 06:14 PM
Posted 20 December 2007 - 06:25 PM
yes a stage 1 kit normally comes with a new needle
Posted 20 December 2007 - 06:33 PM
Where can i get one?
As i just collected my other parts from friends and im trying to get the full stage 1.
Edited by shaun_89, 20 December 2007 - 06:33 PM.
Posted 20 December 2007 - 06:56 PM
pm simon@minispares and he sould be able to sort you out with what they supply with their kits
Posted 20 December 2007 - 07:25 PM
i thinks its bbw but dont quote me, could stil vary from car to car as with major mods tho!
Posted 20 December 2007 - 10:27 PM
You don't just need one to get the best out of your kit, you need one to prevent the engine melting down internally as the existing one will be far too lean for a properly setup stage 1. Stage 1 kits are normally properly developed collections of matched parts, not just a random selection. A trip to the rollers is even more important than with a normal stage 1 since you don't actually have a stage 1 kit, you are just doing your own tuning. Any needle suggested here will only be a guess.
Posted 21 December 2007 - 01:32 PM
The general needle depends on engine size,
a stage one is AAU as standard, and AAC as stage 1, (or vice versa).
a 1275 is different, I can't remember as I'm running an MG Metro setup with modified carb and needle...
Anyway as Dan says, getting it set up properly will get the most from your new parts.
D
D
