I plan to rattle can my mini, mat black
There is already paint on there so i could just key it, but is it better to key, primer and then paint? (All if this will be done with rattle cans)
If so, after primer, do i need to do any rubbing down, or does the mat go straight onto the dry primer?
Rattle Cans
MiniKid..
, Dec 21 2007 12:12 AM
4 replies to this topic
Posted 21 December 2007 - 12:12 AM
Posted 21 December 2007 - 12:46 AM
although you want a matt surface you also want a smooth surface - give it a rub down
Posted 21 December 2007 - 08:55 AM
OK, so primer nd rub it down.
What grit paper?
What grit paper?
Posted 21 December 2007 - 05:28 PM
Same as any paint job!
Look in the sticky at the top of the page.
Posted 21 December 2007 - 07:49 PM
800 grit used wet have fun!!!
