Steering Column Removal
9 replies to this topic
#1 billyboy83
billyboy83
  • 262 posts
  • Local Club: www.16vminiclub.com
Posted 26 December 2007 - 08:51 PM
Hi people
I have done a search but could not see any think really. I'm having slight problems removing the steering column from the rack. I have followed the way Haynes says to do it. undone the pinch bolt and rack mounts, used a 6mm pin to hold the rack in central position while column is discounted. The thing is i have undone the pinch bolt and column mount and i cant get it to part from the rack. Has any one got any idea's how to get it to part i have tryed pulling it and have sprayed some penetrating oil on it the retryed a hour or two later and still no joy.
Thanks Billy
Edited by billyboy83, 26 December 2007 - 08:52 PM.
#2 jonny d
jonny d
  • 1,148 posts
Posted 26 December 2007 - 08:59 PM
Hi there you say that you have undone the pinch bolt, you have to take the bolt out for it to part hope this helps J.D.
#3 billyboy83
billyboy83
  • 262 posts
Posted 26 December 2007 - 09:53 PM
Hi mate i forgot to put that yep i have taken it aswell mate.
#4 jonny d
jonny d
  • 1,148 posts
Posted 26 December 2007 - 10:06 PM
Try putting a screwdriver in the slot at the bottom of the column and spread it a little
#5 billyboy83
billyboy83
  • 262 posts
Posted 26 December 2007 - 10:17 PM
:D >_< Done that as well. wast tempted to get a bolt joint remover or a crow bar and and try and prise it of by wedging it under the column part where the bolt goes thought and the body but i have a feeling i will put a dent in the shell before it moves.
#6 il-barba
il-barba
  • 839 posts
  • Local Club: malta mini
Posted 26 December 2007 - 10:39 PM
you have to undo also the bolt on the outer column, which attaches it to the frame. its usually a shear bolt
#7 billyboy83
billyboy83
  • 262 posts
Posted 26 December 2007 - 10:43 PM
the bolt at the top, near the control stalks ? if so i have done that >_< also tryed turning it to full lock both ways to see if i could get it to free its self and still nuffink lol
#8 il-barba
il-barba
  • 839 posts
Posted 26 December 2007 - 10:48 PM
yes thats the one.
when i had to remove mine, i had to open the slot a lot so it came out. not just a small screwdriver. try opening it more and while youre there spray some more penetrating fluid
#9 billyboy83
billyboy83
  • 262 posts
Posted 26 December 2007 - 11:13 PM
yes thats the one.
ok thanks i give it a go, tomorrow once i been mini spares to pick up some bits
Thanks Billy
#10 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 26 December 2007 - 11:15 PM
It is possible if the column is allowed to drop after the pinch bolt has been removed that it can drop furter onto the pinion than the length of the spline inside the column. The spline on the pinion is then within a void at the bottom of the column and effectively out of mesh with the spline inside. The two being out of mesh will stop you sliding it off, try rotating the column each way a little as you pull to re-engage the spline. Once it's back in mesh it should slide easily, if that is actually the problem.
