i got water coming into my drivers footwell when the car is stationary, coming from the corner where the inner arch is. This occours when i pour water over the drivers door and A panel, so is there any seal or something over than the main door one which could be causing this? cheers, MIke
Door Seals
mike49
, Dec 27 2007 01:14 PM
3 replies to this topic
Posted 27 December 2007 - 01:14 PM
Posted 27 December 2007 - 01:18 PM
theres only the door rubber you can see
or it could be hitting the door glass and going into the door and coming out behind the door card
make sure the rubber thats at the bottom of the door glass is in good nick, the drain holes are unblocked in the bottom of the doors and there is a waterproof membrane under the door cards
Posted 27 December 2007 - 02:26 PM
Could also be caused by perished door check arm seals, so worth making sure they are present and looking ok!
Posted 27 December 2007 - 02:52 PM
i rekan its just getting behind the a panel somehow and seeping along to where the inner arch begins as there is no evidence on the door of it getting past the seals etc, although the arm seals do look like theyve seen better days
