hi people i plan on puting and inline switch on mi live feed 2 mi ignition barrel ,and hide de switch so it wrks as a imbosiliser :grin: ,however i cnt find any wer nt 2 obvious 2 hide it can any 1 give me ideas or advice if uve fitted 1 urself
cheers
homemade imobillisers
dave 17
, Mar 20 2005 05:59 PM
11 replies to this topic
Posted 20 March 2005 - 05:59 PM
Posted 20 March 2005 - 06:08 PM
WEL IF U DRIL A HOLE IN TEH MIDLE OF DA BONET AND WIER IT UP 2 TAHT!1111 what the hell TRY 2 WRAP DA WIER AROUND DA 3NGIEN A FEW TIEMS 2 KEP DA WIER HOT OTH3RWIES IT WONT WORK1111!1 OMG what the hell IF U WRIET ""PUSH THIS BUTON 2 START 3NGIEN"" THEN U WONT FORGET WUT IT DOES.!!!1!11!!111!! what the hell
Posted 20 March 2005 - 06:10 PM
:tongue:
Sorry, Had to be done dude.
You will need a switch which is capable of taking a high current otherwise it will melt!
Erm, What about underneath the Dash rail. Or on the cross section...
<|Ben|>
<|Ben|>
Posted 20 March 2005 - 08:04 PM
You could put a switch in the boot or under the rear bench seat.
Posted 20 March 2005 - 08:39 PM
the boot seems like the best bet at the mo
:grin:
:grin:
Posted 20 March 2005 - 10:42 PM
Just pull the coil HT lead before leaving yer car overnight! works for me...
Posted 20 March 2005 - 11:38 PM
It is possible to take one plug lead off and fit it from the coil to the dizzy, so taking one lead isn't really secure. A Mini will start on two cylinders so three's a doddle.
Posted 20 March 2005 - 11:56 PM
i use the switch under the dash approach, just splice it into the ignition and if you've hidden the switch well enough, then its not going anywhere
Posted 21 March 2005 - 12:00 PM
Or just stick it right on your dash, but use a hazard light switch or something so its disguised, that way, its always to hand, but only you knows what it does. Just make sure you tape the wires with everything else so no one else can trace the wires to your ignition!
Posted 21 March 2005 - 05:29 PM
tee hee done this many times befor... totaly useles.... brought some mdf from do it all and put it in and jumped in started it up and drove off lol pulled straight over and swaped them back lolJust pull the coil HT lead before leaving yer car overnight! works for me...
minis run and drive on 3 cilinders shaky but ok lol i would suspect it would run on to but not drive to!.
best place to put that swich mate is under you seat!
Posted 24 March 2005 - 09:11 PM
cheers 4 ur help people decided 2 put it in boot
Posted 24 March 2005 - 10:54 PM
d'oh! didnt think of that! Id better go outside and check theyre still there...
