This seems like a silly question to me, but im trying to change the wing mirrors on my Mini, do i really take the door panel off and try and undo the two nuts through that tiny hole, or is there another way to do it, please help.
I thought this was an easy job.
G
Wing Mirrors
glennthrower
, Dec 30 2007 11:31 AM
3 replies to this topic
Posted 30 December 2007 - 11:31 AM
Posted 30 December 2007 - 11:59 AM
If they are factory fit mirrors they are held by two captive nuts that are fitted in to the door skin and two screws , so there should be no need to strip the door card off, Under a standard mirror there is a plastic cover on the underside that you prise off to reveal the two crosshead screws
Edited by webweavers, 30 December 2007 - 12:02 PM.
Posted 30 December 2007 - 12:10 PM
If they are held on by nuts and bolts you can wind the window right down, take off the door seals and get to the nuts that way.
I managed to do it, then again I managed to "lose" 2 or 3 nuts down the inside of the door at the same time good fun though...
Posted 30 December 2007 - 05:22 PM
ah thanks guys, all done now, tasking the window down worked
G
G
