Car starts from cold every time, no problem, runs at elevated revs (function of ECU acting like a choke I guess?) for about 5 mins and as soon as it is warm, revs drop back and engine ticks over no problem. On driving away (i.e. engine under load) and engine still only "warmish" it runs without missing a beat but as soon as it has run for about 15-20 minutes (up to operating temperature?) the hesitation starts. While progressively pressing the throttle their is a hesitation to pick up which does not clear until I press pedal to the floor! Hesitation and Splutter is evident also when trying to "feather" the throttle, i.e. when motorway/dual carriageway driving.
Electric fan is cutting in and out at what seems to be the right time, it certainly takes 1 good 15 minutes or so before cutting in when stood ticking over.
Also, (see previous posts) there was a full diagnostic checkover with several parts changed only 900 miles ago.
Not sure what more I can say?
Engine is coming out soon for gearboe it and everything x rebuild at which time it will get a thorough clean and checkover.
I have expirience that a few months back. It took me about three weeks to solve it. Finally I found that my rubber vacum joint for MAP cracked. Replaced it and everything fine. But mine is SPI, not sure wheather same or not with yours.
Hope this will help..
