Changing A 1275 Metro Auto Engine Into Manual
19 replies to this topic
#1 mini_lad_deacon
mini_lad_deacon
  • 277 posts
  • Local Club: tynemouth
Posted 31 December 2007 - 02:36 AM
im just wondering if youve got to change cams or anything like that to change a auto 1275 engine into manual 1275,i know you have to have gear box but what else must be changed . thanks Dee
Edited by mini_lad_deacon, 31 December 2007 - 03:18 PM.
#2 miniboo
miniboo
    Lord of Original Thinking
  • 9,327 posts
Posted 31 December 2007 - 04:10 AM
the whole engine.
the block of an auto is different to a manual block so it isnt just a case of bolting on a new gearbox.
easiest way is to do a complete swap
#3 mini_lad_deacon
mini_lad_deacon
  • 277 posts
Posted 31 December 2007 - 03:16 PM
hmm am sure u can change it to manual somehow..
#4 Ethel
  • 26,104 posts
Posted 31 December 2007 - 03:22 PM
The oil passage junctions with the box differ I believe.
#5 stickycreambun
stickycreambun
  • 1,865 posts
Posted 31 December 2007 - 03:23 PM
possibly maybe, but after spending 3 times the time effort and money is it going to be worth it?!
you could pick up a nice low milage complete 1275 for £150 max.
Edited by stickycreambun, 31 December 2007 - 03:24 PM.
#6 minimender
minimender
  • 1,589 posts
  • Local Club: M.M.M.
Posted 31 December 2007 - 03:45 PM
Didn't read the post properly before answering. :thumbsup:
Edited by minimender, 31 December 2007 - 03:47 PM.
#7 Retro_10s
Retro_10s
    Moderator
  • 10,139 posts
Posted 31 December 2007 - 04:40 PM
You cannot interchange the blocks on manual and auto engines,.. neither can you interchange the gearboxes, the oil galleries are totally different and will not line up. engine go bang.
You can re-use the ancilleries (dizzy, radiator etc) and the head. That's it.
You'll also need to buy a new subframe or some Converison spacers from minisport.
No. You can't. sorry :thumbsup: You need to buy a 1275 short engine, block, crank and pistons, to go on your manual gearbox.
Edited by Retro_10s, 31 December 2007 - 04:41 PM.
#8 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 31 December 2007 - 05:00 PM
Well technically you can but it's not easy. Someone on here did it at home once but it isn't really worth the work involved and is very easy to get wrong. The bare castings of each block are from the same tool, it's the machining that's different. You need to drill some new oilways and plug some existing ones but that means you have to drill some really long/deep holes, very accurately through cast iron and end up with the hole coming out in the right place. As I said, that isn't easy.
In short, it's not easy. If you aren't an experienced engineer you will only mess it up so don't try. Just buy a new engine and let someone who might need an auto block use the one you have rather than destroy it.
Edited by Dan, 31 December 2007 - 05:01 PM.
#9 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 31 December 2007 - 05:08 PM
There are 'some' 1275 auto's which can be changed, without too much hassle... I have one down the unit which has already been machined but the oil filter connection has been blanked off with a plate.... this suggests that by just blocking up the feed in the bottom of the block, and then putting on the filter housing... the conversion would be done...
I don't think there are any other oil way modifications required other than that...
#10 Retro_10s
Retro_10s
    Moderator
  • 10,139 posts
Posted 31 December 2007 - 05:09 PM
muuuuuuuch easier to find a 1275 engine and re-con....
#11 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 31 December 2007 - 06:05 PM
I can't remember exactly what it was that the chap who did this before had to do to make it work but there was definitely some oil way drilling. I think you'll find that under that plate is where the two supply oil drillings that feed the main gallery have to meet as they are at different angles. There is some reason that it won't accept a standard filter head directly there but I can't remember what. Is there not also an extra drilling out of the oil pump housing for supplying the low pressure pump to deal with? Or was that only on early autos? I may go off and search for the thread now.
In any case it won't just fit directly onto a manual box.
#12 stickycreambun
stickycreambun
  • 1,865 posts
Posted 31 December 2007 - 06:35 PM
so by the sounds of it you could build yourself a 1380 torquetastic monster for less cost and effort!
#13 mini_lad_deacon
mini_lad_deacon
  • 277 posts
Posted 31 December 2007 - 06:41 PM
its pritty hard to come across a manual engine for unter 200 quid , so i need a block basicly but could use everything else off the automatic ?
#14 imabitnaughtyxx
imabitnaughtyxx
  • 4,619 posts
Posted 31 December 2007 - 06:43 PM
i beg to differ... there have been and are, a number of 1275 manual engines for sale on the forum under £150!
#15 mini_lad_deacon
mini_lad_deacon
  • 277 posts
Posted 31 December 2007 - 07:57 PM
are sold straight away tho , erm so would it be worth bothering to do anything with the automatic engine and box ...
