Deseamed Mini
19 replies to this topic
#16 Jobu
Jobu
  • 508 posts
  • Local Club: 16vminiclub
Posted 01 January 2008 - 06:58 PM
much better than that chavs favourite you get at them motor mania places ha ha ha you know the stuff looks like porridge !!!!!
What is the best way to do the job or is there a best way ?
What the stuff that 99% of bodyshops use? No matter how expensive the cars! :proud:
#17 i love my grey mini
i love my grey mini
  • 144 posts
  • Local Club: www.dcmoc.co.uk
Posted 01 January 2008 - 07:06 PM
im not saying using it is wrong but there is different ways of using it and filling a hole you found on your wing / door full of the stuff then sanding it down aint right
#18 Jobu
Jobu
  • 508 posts
Posted 01 January 2008 - 07:37 PM
Filling holes with filler is a completely different ball park and is just plain stupid! But we're talking about deseaming here!
#19 panelbeaterpeter
panelbeaterpeter
  • 5,606 posts
  • Local Club: n/a
Posted 01 January 2008 - 07:47 PM
As said there is definitely no way of deseaming a mini without using body filler. As for lead filling, it's very expensive to get someone who can do it properly these days, and it's still filling, plus it adds alot of weight. Modern polyester body filler is excellent stuff and if used right will work perfectly. All body shops use it, in anything from a Ferrari to a fiesta. The aim when doing any body repair is to get the area as near to perfect as possible, but 99% of the time you will require a certain amount of filler. Anyone who just fills a dent with it rather than removing the worst of the dent first doesn't know what they are doing, and it's people like that who give it a bad reputation amongst some people.
To deseam, start by cutting sections of the gutter off in 4 inch sections, leaving about a ml of material still remaining, so you have some metal to weld to. it doesn't matter if the weld is slightly proud of the surface, it can be dressed and tapped in slightly if required. carry on this process, cutting off sections, welding them cutting another etc, until you're done. Obviously you'd have to remove the interior etc to prevent setting anything on fire. Unless you're an experienced bodywork person, it's not an easy job to get it looking right. Also, before you cut any of the gutter off, make sure that the roof skin lines up with the top of the windows all around, as it hardly ever does, and can make the job even more tricky.
#20 i love my grey mini
i love my grey mini
  • 144 posts
Posted 02 January 2008 - 12:41 PM
This is the point i was trying to get across you dont cut and fill its quite time consuming and tedious to do a good job and i will be at most mini shows this year and anyone can come and take a look at a proper done job dont get me wrong i have seen some excellent jobs but also seen some very bad ones and as i dont even work in a garage or care to i think the time was spent well doing as much as i could and think the job was done very well
