Spray Gun
Posted 03 January 2008 - 07:41 PM
Any sugestions Budget between 50-100 pounds
Cheers Adam
Posted 03 January 2008 - 08:08 PM
I'm going for the 12c spray gun from machinemart for my 2hp compressor.Check out their website, it's only £20. I'm not sure whether to use it for the whole respray and then get or borrow a better gun for the final coat or use it for everythin but I'm sure the finish will be good enough for atleast primer.Im after a spray gun basicaly just for primer, dont want anything to flashy but that will do the job well.
Cheers Adam
Posted 03 January 2008 - 08:33 PM
Cheers Adam
Posted 04 January 2008 - 07:30 PM
Posted 04 January 2008 - 09:14 PM
Cheers Adam
Posted 05 January 2008 - 04:01 AM
Isn't primer pourous? And thus would just hold water against the bodywork causing it to rust faster?It wont be doing any colour at all, its basicaly just to get primer on as it may have to be stored out side for a week or two.
Cheers Adam
I might be wrong, but I'd rather bring it up and save you finding out the hard way.
Posted 05 January 2008 - 10:11 AM
Stoney
Posted 05 January 2008 - 12:55 PM
used it on my project got to admit i was impressed
Posted 05 January 2008 - 06:31 PM
you use it for the colour aswell?got my priming gun from halfords in a set you also get a tyre inflator cant remember what else but it was only £20 for the set
Posted 06 January 2008 - 11:04 PM
probably wont be suitable for your air compressor tho looking back at your previous post
Edited by minipinkprincess, 06 January 2008 - 11:08 PM.
Posted 10 January 2008 - 11:11 PM
Posted 10 January 2008 - 11:16 PM
Posted 11 January 2008 - 06:24 PM
dont let the sheet have water traps though or you will look a tit like me when you rip it off and you get soaked!!!
Posted 11 January 2008 - 06:56 PM
any top feed HVLP gun would suit for primer get the biggest nozzle you can find. SHARP DEVILLABISSIm after a spray gun basicaly just for primer, dont want anything to flashy but that will do the job well.
Cheers Adam
Posted 11 January 2008 - 11:00 PM
I've been using a 1.4 tip in my gun for everything - should I get a 1.6 for primer ? is this why I'm having to thin it down more than feels necessary?
A 1.4 should be fine for primer, but a 1.6 would be even better and would require less thinning.
