aslo why when you have a single carb , on the inlet manifold their is water holes each end but on the twin manifold their isent why?
ash
this is picture of mine below
Edited by MINI 1, 04 January 2008 - 04:27 PM.
Posted 04 January 2008 - 03:56 PM
Posted 04 January 2008 - 04:05 PM
Posted 04 January 2008 - 04:56 PM
Posted 04 January 2008 - 05:25 PM
Posted 04 January 2008 - 05:33 PM
Posted 04 January 2008 - 05:43 PM
for what ever reason twin carbs dont have a heated manifold
Posted 04 January 2008 - 05:49 PM
Look at your picture again. On HS2 carbs, the brass tubes you see on top of the float bowls are the input ports, not outputs. There are small overflow holes drilled in the lids just below the brass tubes. The only other outlet is the jet tube itself at the bottom of the bowls.
As for the connections between the carbs, the original Cooper and -S setup used a long metal tube with a "T" near the front carb. Short lengths of tubing connected the float bowl lids to this long tube/"T".
I don't understand your question about the water holes.
Posted 04 January 2008 - 05:51 PM
Posted 04 January 2008 - 05:59 PM
Posted 04 January 2008 - 06:06 PM
Posted 04 January 2008 - 06:40 PM
Your floatbowls should have different tops like these, feed one then take off to the other but as has been said you can put a tee piece in.
The overflows are pinholes under the brass tabs.Mini_1.jpg 195.29K 15 downloads
Posted 04 January 2008 - 10:02 PM
Posted 04 January 2008 - 10:47 PM
Posted 04 January 2008 - 10:49 PM
Posted 04 January 2008 - 10:51 PM
