Mayfair Rebuild
37 replies to this topic
#31 beejay
beejay
  • 114 posts
Posted 22 May 2011 - 09:44 PM
Thought I'd show some pics on the fuel tank mounting. The fuel tank was purchased a couple of years ago but for various reasons I didn't seriously look at sorting out a way of fitting it to the car until late last year. I did have ides of cutting the boot floor away to give plenty of room for it but that gets me into all sorts of issues at MOT time.
This is how it turned out in the end. The tank is a 4.5 gallon unit which is baffled and foam filled.
The lower section is 25mm box section steel which attaches to the body with some M10 bolts. Two sides of this are cut out in the middle to create a recess for the tank to sit in. The upper section is 25mm aluminium angle.
All the bits in contact with the tank have some self adhesive neoprene strip applied to cut down vibration, as shown here underneath the upper section.
The upper is joined to the lower with some M6 threaded bar cut down to length. This also show the recess the tank sits in and the short length of aluminium angle used to protect the tank from the sharp edge of the recess.
The M6 bar needed to be turned into a very long bolt (for want of a better expression), to do that two nuts were assembled with copious amounts of threadlock and then locked against each other.
#32 beejay
beejay
  • 114 posts
Posted 09 July 2011 - 08:55 AM
Bit of an update as I've managed tog et everything painted, quite pleased to get this far at last!
Cleaned up the interior, sealed up all the repairs and gave it a coat of primer. Also fitted some footwell panels; some sheets of aluminium treadplate. The drivers side is just sat on the floor and attached with self adhesive velcro to stop it moving around. The passenger side sits on the short pieces of box section welded in earlier. Need to add some rivnuts to screw it to.
In the midst of preparing for paint, the bonnet and boot closing method was sorted out. For both I used these Camlock fasteners from eBay, who supplied six all with the same key.
With all four in it looks a bit like this
Just need to remove the old Dzus fastener bits and want to add some bonnet straps at the front for additional peace of mind.
The fuel pump was also fitted to the rear subframe.
This is fitted to a 5mm aluminium plate and attached using some of the original subframe holes and a couple of extra ones as needed. Just need a hole big enough to get the pipe to the tank in.
And finally, the gear selector got cleaned up and the quickshift fitted.
#33 beejay
beejay
  • 114 posts
Posted 09 July 2011 - 08:57 AM
After much sanding and filling, got to the point where I was happy with the prep work. Or fed up with sanding down, I forget which. So, the car was masked off and then hit with some matt black spray can action.
Its not a perfect finish but will do me. The original paint was keyed up with wet and dry and the matt black applied straight over the top. The areas that have been taken back to bare metal when being repaired were given a coat of etch primer and a few of gloss black, as I was concerned by the stories of matt paints being porous. Hopefully this will give some level of protection.
Once dry, the masking came off, the roll cage went in, and as can be seen things like rear lights and door seals have also been fitted.
The next big thing to get sorted is to rewire the car. This has started with the battery cables given its new location under the rear seat. Also have a cut out switch which needed to be fitted in there too and spent some time pondering the best location for that some time ago. The conclusion was to put it between the seats, hence the mysterious additional bracket seen a few pages ago was welded in. Then an aluminium frame was rivetted together to mount the switch. It also provides something to attach the brake line to and hopefully the rest of the wiring once thats done.
Also had to check it didn't interfere with the harnesses too. The brake line was also run, this pops through one of the existing holes in the rear seat and a new hole on the front bulkhead just behind the heater.
#34 josh.goddard
josh.goddard
  • 398 posts
  • Local Club: Derbyshire Classic Mini Club
Posted 10 July 2011 - 07:34 PM
hi mate looks very nice dont know weather or not you are in derbyshire classic mini club dcmoc.co.uk
#35 beejay
beejay
  • 114 posts
Posted 21 June 2012 - 09:55 PM
Thought I'd update this a bit, as the car is now on the road :) Going to skip some of the more boring bits :)
Got the Fiesta calipers fitted
After scouring eBay for several months I eventually managed to get hold of a fitting kit for the calipers, which gave me the brown piece in the picture. Two of these are used on each caliper to fix it to the bracket and allow it to slide when applying the brakes. I couldn't find these anywhere else, including Ford. The fitting kits I could find for the mark 1 were only the anti rattle spring bits used to fix the pads to the caliper bracket.
Also had to use a washer between the caliper and bracket, as others have, to stop the bracket getting too close to the disc. Calipers were rebuilt with new seals too.
Had a road trip down to MiniSpares and picked up the tyres, dampers and a few little bits and pieces. The dampers are the Kayaba gas variety that MiniSpares do in a nice set of four for a very reasonable sum.
At the front also fitted new pins at the bottom and new upper brackets of the lowered variety. Managed to bugger up the threads on the originals when removing the old dampers all those years ago.
Then moved on to rebuilding the engine, which was stripped down. The gearbox was ok bar a stripped thread on the diff output cover, this was fixed with a helicoil repair kit. A bit of an exercise in drill control and not getting the hole at a daft angle but it turned out ok.
The stripped thread was discovered as the diff output bushes were worn resulting in some considerable play in the output shafts. New bushes were knocked in, which was easy enough, however they also need to be reamed to size to suit the output shafts. After giving up with trying to hone them out to size, ebay came to the rescue with a set of second hand imperial reamers for £10. Sorted. New output seals went in too as no doubt the old ones were knackered with the shafts moving around so much. Last job on the box was a gear selector seal kit.
Decided to pop a couple of bearing caps off the crank just to check the condition of the engine. Unfortunately they weren't looking too good and the quick decoke plan went out of the window. Plan B was to dismantle everything and sort it out properly.
The list of replacement bits got quite big in the end; new cam bearings, mains, big ends and piston rings were needed. New crank thrust bearings too as the end float was way off spec. The timing chain was ok but needed a new tensioner and timing cover seal. Here we are half way through putting the pistons back in the newly honed bores.
the engine block, gearbox and clutch housing were all fitted back together and the block given a coat of paint. Then borrowed an engine crane and dropped it into the bay. One problem with the block was a stripped thread on the rear engine steady bolt. The first plan was to helicoil, until I discovered Mini Spares sell a range of replacement brackets that get around having one or more of these threads being unserviceable. Plus they were slightly cheaper than buying a helicoil kit. Here it is fitted.
This picks up on two of the transfer housing bolts for the additional support needed. The rear bolt screws into a captive nut on the bracket, not into the broken thread in the block.
Made up a simple plate to hold the clutch onto the transfer housing . This angles the coil to clear the air duct. I never liked the original coil bracket, hanging it off one of the head studs.
The cylinder head was stripped down next, cleaned up and dismantled. This just needed a good decoke and a quick going over with a valve seat cutter to clean the seats up nicely. One exhaust valve was quite badly corroded and so will need replacing, just waiting for a new one to be delivered before the head can be fitted.
The thermostat bypass hole was also plugged up on the head. This is a common failure point that I wanted to eliminate, as it was on the later Mini's and the Metro. I made sure the new water pump was a later one which doesn't have the corresponding nozzle on it for a start then attacked the head.
This would have had the nozzle for the bypass hose originally. The nozzle in screwed into the head, but expected it was corroded into place from years of being immersed in coolant; the nozzle just broke off when trying to unscrew it. Plan B was then to remove the remains of the nozzle until it was flush with the head, tap the hole and screw in a plug. In this case a 1/2 inch UNC tap and a cut down bolt were used, with plenty of thread lock to help it seal. Fingers crossed it doesn't leak!
#36 beejay
beejay
  • 114 posts
Posted 21 June 2012 - 10:10 PM
Also sorted out the wiring. The original loom wasn't in great condition and since a few things needed to be added a new loom has been designed and built from scratch. This used some some sections of the original spliced into it to allow the original lights and switches to be plugged in.
Made a brackety type bit to attach the battery isolator to and something to run the wiring and brake lines against. Battery is a small Varley Red Top.
The dash area was chosen as the location for the new fuse and relay box; its clean, out of the way and has more room than anywhere in the engine bay. A couple of lengths of aluminium angle bolted to the dash provided a suitable mounting for the fuse box, relay box and associated wiring.
The main battery cable runs into the 3-way junction box at the top, this splits out into a high current cable to the starter and a bunch of (relatively) low current cables to the fuses. The relay box has a relay to provide power for the main and dipped beams, the starter solenoid and a changeover relay for the fuel pump. This is wired to the oil pressure switch, hence on low oil pressure the relay is switched on and the fuel pump off. A handy safety measure I picked up from somewhere.
Over to the right and rest of the dash is in place.
Went with a 2-clock dash in the end, although a 3-clock with rev counter would have been nice. Problem is that it wasn't that easy to see through the steering wheel. Ended up mounting the rev counter in the centre of the dash.
As the picture shows the position for the original switches (for the lights, hazards etc) is now inaccessible as someone has put a roll cage in the way. A new location was required for the new switch panel, ended up attached to the upper bar of the roll cage.
With the engine in the front brake flexible lines could now be finished off. The Fiesta conversion means custom flexibles are needed and despite trying to sort these out earlier it was only possible to confirm the correct length with the engine in which got the car at the right ride height.
Rally Design supplied the appropriate braided line and fittings to suit the metric caliper and imperial Mini. A straight connector into the caliper was attempted first but the resulting S shaped hose looked a bit tight for space and bend radii. Hence, as others have, I used banjo type fittings at the caliper end instead. After much messing about with looking at where the car end could sit I just went with the standard type connection to the hard line on the subframe.
#37 beejay
beejay
  • 114 posts
Posted 21 June 2012 - 10:20 PM
Then, skipping right to the end, this is the enginebay after its all been re-assembled
And from the back...
Exhaust is a side exit RC40 twin box system that I cut up to make into a centre exit. Boot is glassfibre, wanted the straps to make sure it doesn't pop open!
Wasn't sure what arches to go with but thought I'd see how the sportspacks work with the wheels. Sorted out the grill and painted the roof after this, it now looks like this
Bought the van grill insert ages ago with the intent of welding it in. Then thought better of it as it would make maintenance access even more tight. Instead this has been trimmed down a bit and screwed onto the A panel. A mark 1 grille would be nice but a bit too expensive at the moment.
Passed MOT with no problems and now remembering what its like to drive a Mini again! Needs a decent tune up I think but apart from that alls well (so far!)
#38 grahama
grahama
  • 2,442 posts
Posted 22 June 2012 - 08:22 PM
Must add my bit too. Great work, very thorough, very impressed. Keep it up.
Graham
