Sprite Wiring Diagram
Posted 07 January 2008 - 10:01 AM
Also, does anyone know if the coil is 12v or 9v ballast? I'm hearing conflicting reports.
Posted 07 January 2008 - 04:39 PM
Posted 07 January 2008 - 04:43 PM
Posted 07 January 2008 - 05:15 PM
Posted 12 April 2009 - 06:59 PM
Did you manage to find a wiring diagram for your sprite?
I have a 1993 Sprite, 1275 Carb
I'm trying to replace the engine bay loom but half of the loom seems to SPI, as i have the yellow relays in the engine bay but obviously i don't have an ECU plug on the loom cause its a carb model.. so unsure which loom to buy, to replace my existing loom.
See pic..
If you have any idea's where to get a loom, or a diagram I'd really appreciate it!
Joe
Edited by joeuk2000, 12 April 2009 - 07:00 PM.
Posted 16 April 2009 - 01:33 PM
1994 Sprite 1275 single carb.
The Haynes manual doesn't seem to know anything about my loom. I have had the CD for some time and can't find a diagram that seems to match. I'm beginning to think they made it up as they went along in those days.
Anyone know a source of the "right" diagram?
Posted 27 October 2009 - 08:50 AM
PDF versions of the wiring diagrams for a series of minis.
http://new.minimania...on/ArticleV.cfm
Posted 14 September 2013 - 10:55 AM
i need one for a 1994 built sprite (carb model) as it seems i dont have a radio loom in the car!!!
Posted 14 September 2013 - 03:12 PM
You have a PM Cal
Posted 21 May 2014 - 07:24 PM
looks like I am in the same boat, I have just bought a 1994 Mini 35 which is based on the sprite and am looking for a wiring manual, I also have the yellow relays.
Posted 21 May 2014 - 07:25 PM
Hi,
I have a '94 carb sprite and I think the 1275 diagram covers our car. I will dig out my haynes manual and tell you what pages I think cover it .
Rod
Posted 22 May 2014 - 06:46 PM
Thanks Rod
My new haynes manual should arrive tomorrow so will see if I can spot it - If not guess I will have to draw one!
Posted 24 May 2014 - 01:20 PM
Right, I reckon page 227 in section 10 is the right car (but I could be wrong). the diagram is titled for the 1275GT. It may not be 100% but I thought it was close.
Rod
Posted 26 May 2014 - 10:04 AM
Hi Rod
My Haynes manual must be a different one because that does not tie up - the one I have (1969 - 2001 up to X reg) does not have the wiring diagrams, which are in chapter 12, for ours, the injected ones are the closest so I am working from them and drawing my own, many thanks for guidance though.
Posted 03 January 2016 - 12:26 AM
Many thanks James
