Gap In My Door!
Posted 07 January 2008 - 04:58 PM
What can I do to fix this?Does my door need to be taken off and given to someone to straighten it up again?
Many thanks in advance
Posted 07 January 2008 - 05:05 PM
I was washing my car the other day, and using the water hose to wash off the dirt I later found out I had splashes of water on my seat! Further inspection told me that there is a gap in the top right where the door frame bends when the driver side door is shut. There is not rust or anything like that, and the door seal/sponge thingy seems in good condition all the way around. It looks to me like the door has been bent a little bit from the top.
Perhaps the frame is weak at a joint along it somewhere? Have you tried carefully bending it "in" when the door is open and see if that works?
If all else fails don't use the hosepipe, I never do!
Posted 07 January 2008 - 05:26 PM
Posted 07 January 2008 - 05:32 PM
I had this problem and a new seal fixed it...
Posted 07 January 2008 - 05:35 PM
Posted 07 January 2008 - 05:38 PM
Posted 07 January 2008 - 06:01 PM
the only doors that will perfectly are the doors it was made with
