My Scuttle Is Looking Bad!
#16
Posted 08 January 2008 - 07:25 PM
#17
Posted 08 January 2008 - 07:26 PM
so surely all you need to do is to take it bck t metal, sealer inbetween the gap, prime and then paint on top. but not too much paint.
#18
Posted 08 January 2008 - 08:26 PM
i'd like to know how to remedy this, too!
The paint on the seams under reggie's headlights has split
Both sides need to be taken back to bare metal, and the seam should be sealed with a good quality PU sealer such as Sikkaflex. The sealer can be left low to preserve the seam, then primed. It should not be filled with bodyfiller. It shouldn't crack like that again. But it must be clean, bare metal underneath. There is, unfortunately, no substitute for preparation!
Roger
#19
Posted 08 January 2008 - 08:44 PM
Edited by Teapot, 08 January 2008 - 08:45 PM.
#20
Posted 08 January 2008 - 09:18 PM
It's body flex that cracks it, not bad quality workmanship, although it's obvious that it's highly unprofessional to fill the gap with body filler as opposed to sealer, as it has virtually no flex. Also, if it's original it will be welded, but spot welded lower down, where the leading edge of the wing joins the scuttle.
For appearances, it looks best without sealant if it's a neat panel join, but if you want to keep rust at bay, it's best sealed and just live with the crack! After all if the correct sealer has been used, the sealer itself won't have cracked, just the paint. On mine, I very carefully dropped paint into the crack, to seal it and it's worked so far! In future I'll probably seal it, but push the sealer lower down the join, so when it cracks it's not visible.
Edited by panelbeaterpeter, 08 January 2008 - 09:20 PM.
#21
Posted 09 January 2008 - 08:28 AM
I do have the same problem personally, what it the best method to remove this seam sealer once it has stated to crack and deteriorate?
#22
Posted 09 January 2008 - 11:10 AM
This seems an issue that is affecting many people.
The seam sealer remains stiff but flexible. If it's a good quality PU, it shouldn't come unstuck easily - that's why I apply it to bare metal before priming, so the paint can't form a weak link and crack. Removing PU is a serious pain - it sticks extremely well!
You need a paint factors to buy it - it comes in mastic-gun type tubes, or 'sausages' for air guns. Unfortunately it's difficult to seal for re-use once a tube is started, but I always have a tube on the go in the workshop as it has a thousand and one household uses! Stick two bits of metal together with it, and see if you can get them apart a week later....
Roger
#23
Posted 09 January 2008 - 11:41 AM
but i think on later minis PU selare or similar was used, and alas there is no way of preventing this flexing and as a result the paint will crack, as pete said a careful bit of touch up is the only solution without removing all sealer and repainting which is costly and time consuming.
#24
Posted 10 January 2008 - 02:10 PM
Edited by pinch, 10 January 2008 - 02:14 PM.
#25
Posted 17 January 2008 - 08:39 AM
I suppose I am lucky as I can (sort of) spray a car and mine needs to be done again, so I gently cut at the sealer with a stanley knife as close to the metal as I could, then got a thickish dinner knife with a serrations and then gently sawed the sealer away. I then carefully poured thinners on the remaining sealer, this did soften it enough to allow all to be removed.
Added jenolite a few times as rust was beginning to form. Once that process was completed injected primer (dam handy wife is a district nurse) into the joints. Once painted I will follow Pinch's idea about injecting Dinitrol into the gap.
All that took me 2/3 hours a side, but hopefully does a long lasting fix............ Here's hoping!
#26
Posted 17 January 2008 - 06:50 PM
Ah ha! I was planning to do this when I replace my front end. Do you get any water and rubbish coming up from underneath?when i rebuilt my mini i had to replace a scuttle end, and made sure the water could run between the scuttle and the wing, thus i have no water trap. all bare metal was painted prior to fitting the wings to seal the metal.
