Hi Guys, Thanks for all the previous info you lot have giving me on my posts.
Next question is fitting a boost guage, how?
Do tou tap into the return pipe coming from the bleed valve to the actuator? Or do you take a pipe from the brass connection on the inlet side of the turbo?
I have noticed that on other turbo cars i have seen at the shows that one side of the brass connection is not used! What was the two brass adaptor originally used for? Thanks Guys i might get riund to posting some pics of the engine soon, see what you all think!
Boost Gauge
1275MIN
, Mar 27 2005 07:43 PM
3 replies to this topic
Posted 27 March 2005 - 07:43 PM
Posted 28 March 2005 - 09:32 AM
A boost gauge should be connected to the inlet manifold, this way you know the actual boost pressure the engine is getting.
The brass connection - One side usually goes to the ECU and the other to the actuator. If you have binned the ECU, then you can either put a bleed valve on this connection or block it.
Lets see some pictures !
Phil.
Phil.
Posted 30 March 2005 - 05:25 PM
Thanks Phill,
where do you take the T-off for the boost guage, i have a few inlet manifold connections such as the dump valve, and another one which would be the best to use?
Posted 30 March 2005 - 10:45 PM
Mine is on the same connection as the dump valve. Works ok.
Phil.
Phil.
