i have mk1 rear lights, but a mk3 wiring loom.
i am fitting new spade connections to mate the two because the old bullets are ratty and dont fit the plastic plug.
quick question.
on the lights there are 3 wires green/purple geen/red and plain red.
im not sure which the plain red wire should connect to.
cheers
Quick Wiring Question
$way
, Jan 10 2008 11:47 AM
8 replies to this topic
Posted 10 January 2008 - 11:47 AM
Posted 10 January 2008 - 11:59 AM
Green/Purple is brake light, Green/Red will be an indicator so they must have spliced in the red for the rear light, although it shouldn't be just red... could it be Red/Green?
Posted 10 January 2008 - 12:01 PM
is solid red not a standard colour then?
basically i just want to know then which is the rear light on the mk3 loom? is it red/green?
cheers
cheers
Posted 10 January 2008 - 12:07 PM
You not looked at a wiring diagram?
My 63 Hornet has an 82 loom in now. Just look in the haynes as BMC being BMC kept all the wirire colors the same. So on a 63 right to late mini the wire colors are the same.
That and the diagram has all the colors written on it.
Anywho,
GREEN PURPLE wire is for the rear lights when the pedal is pressed.
Rear lights (Like sidelights) is RED GREEN.
Anywho,
Posted 10 January 2008 - 12:10 PM
red = tail lamps and no plate
green/purple = stop
green = ind
green/purple = stop
green = ind
Posted 10 January 2008 - 12:11 PM
Lights are fed from the loom by a red/greenred = tail lamps and no plate
green/purple = stop
green = ind
Posted 10 January 2008 - 12:43 PM
Might be of some help.
[attachment=47305:Vehicle_...or_codes.doc]
Posted 10 January 2008 - 02:51 PM
Plain red was the standard colour for the sidelight circuit on a Mk1, there is nothing wrong with that at all. Connect the red in the cluster to the red/green of your cars sidelights circuit. Specifications DO change, quite often.
Posted 10 January 2008 - 05:30 PM
yeah i sorted it all earlier. cheers.
