Anyone experienced water trickeling down the inside of the wheel arch only when driving in wet weather ? Making a puddle by my feet. The windscreen is perfect so it+s coming from somewhere and theres a lot of it !
I´ve had to pull up the carpet as it was saturated. Maybe it#s coming in through that black air vent piping or through a rust hole. Has anyone experienced anything like this and how did you sort it.
Water Getting In !
thevinnyofoz
, Jan 12 2008 12:36 AM
3 replies to this topic
Posted 12 January 2008 - 12:36 AM
Posted 12 January 2008 - 12:38 AM
Try checking the steerig column... Rupert's water comes from there for some reason my body guy hasn't figured it out yet
Yeah, i looked behind the lining of the dash area, prodded it with my finger and it went through. It was the top of the inner wheel arch that was the problem, underneath the scuttle
Posted 12 January 2008 - 01:13 AM
Rust around the air vents in the inner wing is the usual cause unfortunately
Leak through the steering column hole - fit a ball joint dust cover between the rack and the floor.
