My mini came with the doors but they weren't attached. They just have the hinges with the threads on them. What I want to know is when fixing them to the car, what needs to go the other side? I don't want to just put nuts on as they will just pull through the metal eventually and fall off. Is it a case of just using big old washers or is there a specific part used on minis that I need to get?
Hanging Doors
Adcuz
, Jan 13 2008 07:47 PM
4 replies to this topic
Posted 13 January 2008 - 07:47 PM
Posted 13 January 2008 - 08:21 PM
just some washers
you might also need some shims between the hinge and the hinge panel to put the door in the middle of the hole
Posted 14 January 2008 - 08:32 AM
just some washers
They originaly had some farily thick oval plates that fitted over the studs: minispares part number ALA6381.
They also used alloy shims as mentioned above, but I don't know if these are available any more....
Posted 15 January 2008 - 08:44 PM
this is what you need 2x each door
http://www.minispare...s...;ty=fi&rt=1
or minispares part no ALA6381 if link not working
Edited by macfoot, 15 January 2008 - 08:46 PM.
Posted 15 January 2008 - 08:49 PM
Thanks for that Macfoot! Just what I was looking for it seems. I went to see someone I know who does mini restoration for a living, he gave me something similar to this as a template so I will just fabricate some out of a bit of steel.
