Help Me!
16 replies to this topic
#1 theyoungone
theyoungone
  • 90 posts
  • Local Club: crewes missiles
Posted 13 January 2008 - 11:04 PM
im thinking of putting a smooth boot on my project mini but i dont like the handle at the top to open it and dont want to spoil it with bonnet pins etc so i was thinking about door poppers. so like when you press a button on your remote it unlocks the boot so you can pull it down. now heres the problem i cant find a kit that will do that for a mini anywhere plus because the boot handle is a twist handle to lock rather than on other cars where you shut the boot and its a clip onto a hook that locks the boot i have no idea how it would work. so has anyone got any ideas on what i could do? the reason i want the boot to fold down is because i have 2 12" 1600watt vibe subs that i want to build into my boot and would like to show them off rather than hide them.
also ive seen a mini with a smooth boot but it has a red light across the top about 2 inches down. now im unsure whether its a 3rd brake light or a fog light but i got to thinking and id quite like to put my fog light there insted of under the bumper. has anyone got a clue of how i could go about finding a fog light that would fit there and look good or is it impossible for a fog light to go there??
Attached File  Smoothy.jpg   18.36K   17 downloads
this is kind of what it looks like (had to do an edit to a pic of a smooth boot on paint lol)
cheers
Edited by theyoungone, 13 January 2008 - 11:16 PM.
#2 beetlejuice
beetlejuice
  • 128 posts
Posted 13 January 2008 - 11:17 PM
i know its not the answer you were looking for, but i'm pretty sure two 12s won't fit in the boot. i measured it out once.. an enclosure for twin 10s will though.
#3 theyoungone
theyoungone
  • 90 posts
Posted 14 January 2008 - 05:32 PM
gutted oh well cheers mate that'll save me a load of time! still wouldnt mind being able to get in my boot though lol
#4 i love my grey mini
i love my grey mini
  • 144 posts
  • Local Club: www.dcmoc.co.uk
Posted 14 January 2008 - 05:53 PM
I have got 2 12" audiobahn subs in the boot of my mini in the original audiobahn box as well not an easy fit with the 6by9 up above but it does fit just and also got 2 medium size amps in there as well
#5 insamoufonyx
insamoufonyx
  • 1,633 posts
  • Local Club: NorthSomersetMiniClub.co.uk
Posted 14 January 2008 - 06:25 PM
yeah but for two 12" subs you need a hell of alot more volume of air than the boot space anyway or you may as well just have one 12", one 12 with correct volume of air will sound alot better than 2 12"s with to little volume
#6 Rogue Se7ens
Rogue Se7ens
  • 125 posts
Posted 14 January 2008 - 08:58 PM
I don't know of an aftermarket kit that will do exactly what you are looking for, but I think you could piece something together. I would recommend adding a spring loaded plunger, preferably rounded on the top, to the top of the boot lid that will just catch the lip. Then mount a door popper solenoid to the inside of the lid attached to the plunger. When the solenoid is actuated it will pull the plunger allowing boot to open, and if the depth of the plunger is set right it should push back as you close the boot. Here ebay usually has many door popper kits to choose from, and most come with supplies for 2 or 4 doors, so if it works sell off the other components so someone else can try it too.
#7 i love my grey mini
i love my grey mini
  • 144 posts
Posted 15 January 2008 - 08:01 AM
this just simply isnt true as the audiobahn subs i have got cost a lot of money and paid nearly as much for the proper audiobahn box to match them and it was not custom fit for the mini as i had them in my escort gti before i sold it i didnt think they would fit in the mini either but to my surprise they did and make plenty of bass well too much really for a mini you cant see out the windows properly with it cranked up as they vibrate too much amd it makes your ears ring for hours !!!
#8 insamoufonyx
insamoufonyx
  • 1,633 posts
Posted 15 January 2008 - 04:49 PM
Witch audiobahn subs do you have?
#9 theyoungone
theyoungone
  • 90 posts
Posted 15 January 2008 - 06:15 PM
fair enough. thanks very much for all your help it looks like its going to be abit of trial and error when it comes to this working but i'll try a couple of methods and which ever works best i'll probably post up a quick guide on what worked best for me then if people have the same problem they can use my guide for help but cheers everyone. :wub:
#10 norwegianminiman
norwegianminiman
  • 323 posts
  • Local Club: norwegian mini cooper club
Posted 15 January 2008 - 07:05 PM
id go for two 10" anyday...
#11 i love my grey mini
i love my grey mini
  • 144 posts
Posted 17 January 2008 - 11:53 AM
heres my two 12" that go in my mini will take picture of them in when there is someone to help as it takes two people to lift them in while holding the boot
Attached File  bass_001.jpg   1.19MB   16 downloads
Attached File  bass_002.jpg   1.2MB   6 downloads
not sure what model they are think if i remember right they are competition subs ,i have had them a while as they are very good and they was not cheap (think this is the real reason in keeping them)
#12 theyoungone
theyoungone
  • 90 posts
Posted 18 January 2008 - 01:00 PM
what do people think about using a bonnet pull lock thing on my boot to open it? i thought about using a bonnet interior pull thing to open my boot by feeding the cable down along the inside of my car and into the boot and then some how fixing the mechanism so when i pulled the handle the boot was released and it opened. i was thinking about mounting the handle either in the back or down near the bottom on my seat next to the door cill. the only problem i could think of would be running the cable through in such a way that it doesnt catch on anything and that when i pull it the boot actually undoes. if anyone thinks it might work or can see some fatal floors in this idea then please let me know otherwise i think i might try it and see what happens.
#13 Bristolboy
Bristolboy
  • 291 posts
Posted 18 January 2008 - 01:07 PM
The back of that mini looks well nice, how did you get rear lights like that?
#14 i love my grey mini
i love my grey mini
  • 144 posts
Posted 18 January 2008 - 04:21 PM
Rear lights are easy to get hold of but a lot of work to get them in right i didnt know the correct term for it but i am told its called "frenching them" there is a few more pics of the whole car on here somewhere its different!!!
#15 ginger_monkey
ginger_monkey
  • 1,080 posts
Posted 18 January 2008 - 06:52 PM
Take a look at my project and it's covered a bit in there. Link in my siggy at the bottom.
