I had an A series engine in there, that worked fine so I am sure the master cylinder is working OK.
It's an A+ fitted with a diaphragm clutch set up. It's also fitted with.......
Ultralight flywheel (including spacers),
Ultralight pressure plate,
Orange diaphragm,
New clutch plate,
New plunger,
New hydraulic hose,
New slave cylinder and return spring.
So, the problem I had was that I couldn't seem to get it to adjust up enough to disengage.
I've removed the return spring, pushed the clutch arm to take out all of the play, then adjusted the return stop so that it is 0.5mm away from the arm and locked it in place. I've also tried adjusting the throw-out stop by getting my GF to sit in the car, pump the pedal a few times then hold it down, then I've wound the flanged nut up to the casing, got her to take her foot off the pedal, then I've tightened the flanged nut a further flat (60 degrees) and wound the locknut up to it. After I'd done this, I had a pedal that felt OK, but I couldn't quite disengage the clutch to put the car into 1st gear easily, though I could start the car in gear and lift off the clutch and drive (all of 30cm of driving). I also noticed that the revs dropped quite a bit as I tried to disengage the clutch. I am fairly sure that I have bled the system properly too.
Oh, I also noticed that the clutch arm off the old A series 1330 that I took out of the car had a crank in it (see top arm in pic below) and that the one I was trying to set up appeared to be straighter, so I tried swapping those.
Check me crank out. The problem is that I don't know which one is right, if it's supposed to have a crank in it, I could fit that one, but the ball end is worn, so that may create further problems :S
Now then, I was talking to a very knowledgable mini type person on MSN and they suggested checking that the diaphragm spring was flat (as in parallel to the flywheel). They also asked if I'd set the drive straps flat and I couldn't remember, so I thought it best to check those two points.
Tonight, I have just whipped off the clutch cover and inspected both the drive strap alignment and the diaphragm spring alignment. Both of those issues appear OK. So I am more than a little confused.
So, to summarise all of the above, I have a clutch system that seems to have no wear anywhere, yet it doesn't seem to want to disengage. I've tried bleeding the thing with the pushrod disconnected from the clutch arm and the cylinder forced back in as far as it will go (to make sure there is no air in the actual cylinder anywhere).
Somebody please help me as I'm gonna cry!!!!
PS: Sorry for the reaaaaalllly lengthy post! I'm trying to make sure I haven't missed any details!
EDIT: Search keywords:
Clutch lever clevis pin disengage crunching gears crunch <--------might help for future searches???
Edited by The Matt, 10 February 2008 - 11:34 AM.
search words added
