Any ideas what a standard turbo's fuel pressure is?
Fuel Pressure
1275MIN
, Mar 30 2005 05:29 PM
3 replies to this topic
Posted 30 March 2005 - 05:29 PM
Posted 30 March 2005 - 10:44 PM
The fuel pressure regulator should be set at 4-5psi when the engine is at idle.
Phil.
Phil.
Posted 31 March 2005 - 08:25 AM
just to ad it should remain that amount above and boost produced...
so say you get to 6psi boost your fuel pressure should go to 10-11 psi.
If not the boost will blow the fuel out of the carb!
Alex
Alex
Posted 31 March 2005 - 12:16 PM
Ok so would the fuel system be classed as a low pressure system or high pressure????? :
