Coil Wires
Posted 17 January 2008 - 07:13 PM
Posted 17 January 2008 - 07:21 PM
Posted 17 January 2008 - 07:50 PM
Minus went to the dizzy, if that is any help, how old is it.?
Posted 17 January 2008 - 07:55 PM
Later ones had two white and browns on minus one of which went to the dizzy.(other one to tacho)
one white wire on the plus side.
Any help?
Edited by minimender, 17 January 2008 - 07:56 PM.
Posted 17 January 2008 - 09:08 PM
its a c plate.....1000 ccOn my old GT plus was white and green and minus was white and brown.
Posted 17 January 2008 - 09:14 PM
cheers 4 that mate....ill try that and see what happens.nice 1....wilsey.Maybe not that old eh.
Any help?
Posted 18 January 2008 - 12:01 AM
That is all as standard though, who knows what previous owners have done to the car. Butchered wiring is very common.
By the way, please don't use TXT SPK in these forums.
Posted 18 January 2008 - 04:08 PM
whats txt spk then??Black wires are earths and generally don't go to the fuse box. Your car should have ballasted ignition. You should find a thick pink/white and a thinner white/yellow both connected to the positive terminal and a pair of white/black wires connected to the negative (you may find only one white/black). One white/black must connect to the distributor, the other if present will be a tacho feed (this is fitted whether there is a tacho installed or not).
Posted 18 January 2008 - 04:10 PM
That is. No offence meant it's just our rules to use English on this site. We have lots of older members and members from overseas who don't like it or can't read it and just people who find it extremely irritating to try to decode posts. Ultimately people just won't read them if they can't work them out and that doesn't help you. Words are words, numbers are numbers.
Edited by Dan, 18 January 2008 - 04:20 PM.
