Vented Disc Conversion
17 replies to this topic
#16 nicklouse
  • 18,657 posts
Posted 03 May 2022 - 08:13 AM
Thanks niclouse,
I guess the lugs have been machined already or I had original mini flanges if they fit with the setup I had which was metro non vented (metro calipers and the thinner 8.4 metro solid discs).
Just wanted to look at my brake options with the flanges I have.
The discs could well just be mini. With the metro calipers.
#17 lildeucecoop72
lildeucecoop72
  • 112 posts
  • Local Club: Norsk Mini Cooper Club
Posted 03 May 2022 - 10:17 AM
The metro flange will need the 4 lugs machining off so it will fit most Mini wheels. But otherwise they are the same as long as they are not from a Vented set up.
Does that mean there are 2 types of metro flange? One for solid and one for vented?
#18 lildeucecoop72
lildeucecoop72
  • 112 posts
Posted 03 May 2022 - 11:12 AM
Thanks niclouse,
Yes you are right, I had the thin solid 8.4 metro discs (GB364) and these worked with the metro calipers I had. I bought the standard 8.4 mini solid discs thinking this would be fine (21A2612MS) but these have a wider (thicker) breaking surface, and so they were too thick for the the orig metro calipers I had. They didn’t line up.
At first I thought it could be the flange, but I don’t think that is the issue. Probably just a bad mix of mini and metro parts that don’t interchange.
So that means I either…
A: have to keep the discs I bought and buy shined new 4pot calipers (from mini spares) and hope the flanges I have are correct (or spend more money on solid type mini flanges)
B (and cheaper option): repair the metro calipers I have (discussing this on another thread) buy and offer up the same solid metro calipers that I had before.
