Paint, Paint, Paint?
Posted 22 January 2008 - 06:01 PM
im going to spray my car in my garage so could anyone advise me on what paint to use? also how do i know how much thinners i should put in the paint. also where i could buy the paint. i would be very greatfull if ny of you could help me.
Thanks nathan
Posted 22 January 2008 - 06:53 PM
ok im in a bit of a hole at the moment. im going to spray my new project soon but had no compressor expierance. the thing is that there is soo many paints about i havent a clue what kind of paint to buy. i want a hard wearing, shiny, easy to apply and drys relitively quick.
Thanks nathan
The best paint to use is 2k, it depends on what kind of coulor your going for as the mixing etc...
Base coat is mixed with basecoat thinners on 1:1 ratio
Laquer is mixed with hardener and 2k thiners on 2:1 & 10% thats 2 laquer 1 hardener & 10% thinners
Solid 2K paint is the same ratio's as Laquer
You would normaly use basecoat and thinners for a metallic colour and a solis 2k for solid colour.
If your painting in your garage i woud say to get extra rapid hardener.
You should also get a carbon mask to wear
Use a HVLP gravity feed gun as this will reduce the ammont of overspray
Also wet the floor of the garage first as this will stop the dust from being blown up when painting.
When applying base coat you should try and start applying the laquer within 1/2 hour of the besecoat being applied, if the basecoat goes off too much before the laquer is applied you will get laquer peel.
and be carefull you neighbours don't complain as you will get a hefty fine.. lol
Posted 22 January 2008 - 07:04 PM
have a look at what i have done with dolly
Posted 22 January 2008 - 07:18 PM
do you have a link to it?if you have never sprayed befoer why not roller paint it
thanks
Posted 22 January 2008 - 07:28 PM
thanks
Edited by Nathann, 22 January 2008 - 07:29 PM.
Posted 22 January 2008 - 08:21 PM
Posted 22 January 2008 - 08:23 PM
Posted 22 January 2008 - 10:19 PM
these safety measures are there for a reason.
Posted 23 January 2008 - 11:27 AM
then puke, cough your guts up and collapse on the floor for not using a air fed mask connected to a seperate compressor out of the garage.
huh?
Posted 23 January 2008 - 03:47 PM
Posted 23 January 2008 - 05:31 PM
2k paint contains cyanide! Therefore, if you are not using an airfed mask, you are basically breathing in cyanide.
yeh i know i never said i wouldnt wear one lol
another thing anyone know where paint suppliers are? were i can get a range of colours?
thanks
Posted 23 January 2008 - 06:32 PM
takes about a week to dry but at least you did not poison yourself.
this car was mine it had 6 coats of primer and 8 coats of finish by brush!
[attachment=48538:scan0001.jpg]
Edited by Rosslin Racing, 31 January 2008 - 05:26 PM.
Posted 23 January 2008 - 06:51 PM
Posted 23 January 2008 - 06:54 PM
