HI, SHOULD HAVE MY 1330 TURBO BACK ANY DAY.
1. ANY TIPS FOR BREAKING IT IN? WHAT SHOULD I DO.
2. DOES ANYONE KNOW IF VMAX IN SURREY IS ANY GOOD.
3. ANY TIPS ALSO TO STOP IT BLOWING UP WHEN I HAVE IT BACK.
4. HAS LOW COMPRESSION PISTIONS, WHAT BOOST CAN I SFELY RUN?
5. I HAVE A INTERCOOLER FROM A MK4 ASTRA WITH QUITE CHUNKY SAMCO. 53MM, SO EXPECTING A BIT OF LAG, DOES THAT MEEN I CAN CRANK UP THE BOOST?
WHO CAN YOU RECOMMEND FOR MODDED HEADS TO? IM GOING FOR POWER/REALIABILITY!
IM SURE THERES MILLIONS OF OTHER THINGS IL BE ASKING SOON CHEERS
ROLLING ROAD
flameredturbo
, Apr 01 2005 09:29 PM
9 replies to this topic
Posted 01 April 2005 - 09:29 PM
Posted 02 April 2005 - 06:08 AM
Talk to Jammy basturd hes good breaking in new engines .
Posted 02 April 2005 - 09:11 AM
Typo, I'm good at breaking new engines!
Posted 02 April 2005 - 10:53 AM
LOL
Posted 02 April 2005 - 06:06 PM
cheers for that usefull info.
any tips?
cheers guys
any tips?
cheers guys
Posted 02 April 2005 - 07:00 PM
Sorry bout that.
1. I don't know the exact way to bed a new engine in but its something like you keep the revs to 2k for the first 100 miles, 3k for the first 500, and 3k for the first 1000, with oil swaps at those points as well.
2.Yes, from what I've heard VMax are very good.
3.ermm, just don't cain the arse off it all the time. Any keep it well mantained.
4. I think the boost should be about 4 or 6? But you'll have to double check with one of the turbo guys on here.
5.Don't know.
5.Don't know.
Posted 02 April 2005 - 07:02 PM
5. more boost = more lag
Posted 02 April 2005 - 07:37 PM
thank you
Posted 03 April 2005 - 03:01 PM
whats it had done? is therea new turbo?rings?cam?
there are a fair different theories out there for bedding in an engine! though it depends on whats new
if theres a new cam when you first fire it up you will have to hold the revs up to alow the cam and followers to bed in.
As for driving it, you will need to use what(wide open throttle) p to around 4k rpm then let it drop back down, this way the rings ont glaze but theres enough pressure in the cylinder to expand the rings out agaians the cylinder wall to bed them in. il have a read up on the exact way 2night
Posted 03 April 2005 - 04:50 PM
cheers, its had brand new pistons and rings fitted,
the cam is an avonbar phase 2, its not brand new it was in the engine already, all though it has been tacken out and refitted, so i asume the same apply for the followers?
thanks for your help
