The air intake hose is under the RH front wing. That's aboot all I can tell you!
For the heater
Posted 30 January 2008 - 01:47 PM
For the heater![]()
Posted 30 January 2008 - 02:27 PM
Posted 30 January 2008 - 02:36 PM
The only air feed for a standard MPi air intake is the pipe that comes directly from the air filter housing. The pipe you're talking about isn't related to the air filter housing. I believe the one you're talking about is for the heater as Ethel said. The only parts that will be replaced when you fit are the air filter housing (with a K&N cone or similar) and the throttle cable housing clip bit thingy.
Posted 30 January 2008 - 02:40 PM
Ooooooooooh, Dirty Boy!![]()
I think you might have actually said something useful! Now get back to the smut before you start freaking me out.........
Posted 30 January 2008 - 02:42 PM
Posted 31 January 2008 - 06:36 PM
Posted 31 January 2008 - 06:41 PM
the air temp sensor is in the normal filter housing
Posted 31 January 2008 - 07:12 PM
Posted 31 January 2008 - 08:15 PM
Posted 02 February 2008 - 03:07 PM
rover really went to town with the ecu didnt they, no input for an air mass meter.
when aftermarket ecu's are used does anyone use any other sensors or do they just stick with the ones they have?
Posted 02 February 2008 - 03:58 PM
Posted 02 February 2008 - 04:30 PM
it was something thats been in my head for a while, it seems there is enough sensors to keep the engine doing its stuff, but no more then it needs, the bare minimum...is this the case?
Posted 02 February 2008 - 04:49 PM
