hi there...me being dumb here but what other carb set ups can you run...can you run twin carb etc
carbs
t@z
, Apr 04 2005 11:55 AM
9 replies to this topic
Posted 04 April 2005 - 11:55 AM
Posted 04 April 2005 - 11:59 AM
people put all sorts of carbs on
su single + twin
webber single + twin
fish
dellortos
su single + twin
fish
dellortos
Posted 04 April 2005 - 01:10 PM
you can put any carb settup on a normally asperated engine. but when you stick a turbo on then you are limited to just the one unless you go for a twin turbo which i dont think has been done on a mini yet, as you would probably need two exhaust and two inlet manifolds, one each for the turbo's,this would work perfect in a v6 or 8 only really
Posted 04 April 2005 - 08:36 PM
the problem u have is the vacum or lack of it. standerd webbers won't work with aturbo, basicly because the webbers want a vacum to work and the turbo is giving presure.
Posted 05 April 2005 - 05:03 PM
You can run a Weber but it must be specially sealed to use it in a blowthrough setup. If your lucky you may be able to find a Dellorto 40 as used on the Lotus Esprit, and on the Janspeed Turbo A-Series. These are already sealed for Turbo use.
Basically most people stick to the SU as it's readily available easy to set-up and is a top bit of kit.
Phil.
Phil.
Posted 05 April 2005 - 05:40 PM
haha liking the pic
Posted 05 April 2005 - 10:05 PM
The dolortos are still easy to find (turbo esprit) from people that deal in second hand lotus spares, and the beuty of this set-up is that you can use a weber manifold .
or have you considered injection ?
Posted 09 April 2005 - 12:36 PM
run any carb u like on suck through set up!
work the same as a normal carb, bit less power than blow through tho, but certainly something to think about
Posted 09 April 2005 - 04:50 PM
If you can find a Turbo that will accept fuel being drawn through it ......
Posted 11 April 2005 - 04:01 PM
Ther is another way.
On the Tickford Capri they used a normal carb (Webber I think) but built a box around it and pressurised the box. thus the carb was never pressurised relitive to it's surroundings. You'll still have to up the fuel pressure and such, but wotrh thinking about, well for a few minuteds at least......
Wil
Wil
