Anybody know if the correct rear seat back panel (with the 'rotodip' hole in) is available anywhere for a '69 MkII?
Anyone got a good second hand one, if not available new?
And was the rear parcel shelf a different bit of metal for Mk2 and Mk3? I have a good Mk3 one, so if they're the same I'm OK.
I know the front parcel shelf should be 'solid' for the Mk2 - any of these available anywhere?
Roger
Mk 2 Panel Availability
rsk289
, Feb 03 2008 05:07 PM
4 replies to this topic
Posted 03 February 2008 - 05:07 PM
Posted 03 February 2008 - 07:02 PM
have your tryed m-machine
they are very good for panels
Posted 03 February 2008 - 08:41 PM
I'm sure M-machine would do one, if not they'd surely be able to make you one. Failing that, could you not just cut a mk3 panel? I think apart from seatbelt holes they are the same, but they could be welded up.
Posted 03 February 2008 - 10:41 PM
There is one pictured on the m-machine site http://www.m-machine... Panels_420.htm
Posted 03 February 2008 - 11:10 PM
Thanks guys, that's helpful - I've been using Minispares, but M-machine are clearly worth a call in the morning.
The MkIII panel (which I have) has a very large hole in it - I had thought of welding in a patch to make it smaller (MkI and II are the same), but if they can make me one that'll be a lot easier.
Roger
