Converting from 12" to 10" wheels
5 replies to this topic
#1 gsms
gsms
  • 2,285 posts
Posted 06 April 2005 - 04:59 PM
Just wondering exactly what there is to do/change to convert from 12" to 10" wheels?
Cheers. Guido.
#2 Jordie
Jordie
  • 13,567 posts
  • Name: Jordan
Posted 06 April 2005 - 05:03 PM
Depends what year and brake setup your car is running.
Post 84 cars were fitted with 8.4" Discs and spacered rears. To fit 10's, you need to change most parts (not sure which) to 7.5" Cooper 'S' discs.
Pre 84 cars were fitted with drums all round or the cooper discs and you can fit 10's or 12's to these.
#3 gsms
gsms
  • 2,285 posts
Posted 06 April 2005 - 05:14 PM
oh nice, I've seen some cooper S discs on ebay methinks.
Cheers Jordie.
#4 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 06 April 2005 - 09:42 PM
I'm surprised we have not got this in the FAQ yet ( or have we... just off to check )
Nope... not there.. .
anyways...
Going from 12's to 10's...
Assuming you wish to stick with disk brakes and not go back to drums, you will need to convert the 8.4" disks to 7.5" ( or 7.9" which I'll deal with in a mo )
There are a few ways in which this can be done, and none of which are exactly cheap, but assuming you're starting with an 8.4" setup you're halfway there already...
First you will need replacement calipers which will be either genuine cooper 'S' ones ,new or old, or aftermarket 4 pot alloy versions. The cost of any of these will run into the scale of hundreds of pounds.
Second, you will need to change the disk, if you stick with the genuine cooper 'S' calipers you will need genuine 7.5" cooper disks and driveflange, if you opt for 4pot alloys then you can use either the cooper 7.5" disks, machined 8.4" disks turned down to 7.9" or even metro vented disks, again turned down to 7.9", each of which will require the appropriate drive flange. This is not so expensive but will determine your final braking setup.
For reference, if your going from drums, you will need to change the hubs and the outer CV's, and the flexible brake pipes aswell, so sometimes better to find yourself a servicable 8.4" drivetrain first!
#5 gsms
gsms
  • 2,285 posts
Posted 09 April 2005 - 01:17 AM
Oh cool!
Cheers!!
By the by, if you havent already done so, your post would make for great reading in the FAQ section.
#6 Telejmp
Telejmp
  • 184 posts
Posted 10 April 2005 - 06:25 PM
In the classifieds at the back of this months mini magazine, there is someone offering a kit to do the conversion. It doesnt have a price on it though, but says "you wont be dissapointed".
Maybe worth a look. If your interested ill get you the number. Might be worth a call.
pEaCE
Dom
