hi my recently built mini turbo is cutting out at 5000rpm. the engine just dies very cleanly just after the dump valve seems to boost, this happens in gear and in neutral.
why is this happening?
and why is it tacking so long to boost?
thank you
mini turbo cutting out
flameredturbo
, Apr 06 2005 06:54 PM
10 replies to this topic
Posted 06 April 2005 - 06:54 PM
Posted 06 April 2005 - 09:04 PM
i would of said it was fuel related , but if your stopped and out gear and revving to 5k and its cutting out , not likely to be fuel as you`ll not be seing much boost , more info really needed
Posted 06 April 2005 - 10:45 PM
Have you blocked the venting pipe on the float chamber ?
Phil.
Phil.
Posted 07 April 2005 - 06:20 PM
the only other ifo i have at the mo is it only cuts out when the intercoolers connected up, if you disconect one of the pipes ten it revs all day
Posted 07 April 2005 - 08:41 PM
Dont know much about turbos but could the fuel mixture go so lean it cuts out. Could be a incorrect needle or setup.
Posted 07 April 2005 - 11:33 PM
Sounds like there could be a blockage then & it's starving the engine of air. What intercooler you using ?
Or the mixture could be way off and the intercooler affects it enough to cause it to cut out ?
Why not try driving it without the intercooler and see if this really is the problem ?
Phil.
Phil.
Posted 08 April 2005 - 11:06 AM
sounds to me like the carb isn't plumbed up properly, the anti run on valve might not be blocked off properly as phil says, as its only cutting out when it sees boost.
if you take off one of the intercooler pipes then it's just gonna be a normal N/A setup really as the boost will be being pumped into the engine bay instead. so it will rev freely.
Posted 08 April 2005 - 11:22 AM
im off to c the engine builder this after so il mmention the anti run on valve. it will drive all the way with out the intercooler plumbed in
Posted 08 April 2005 - 01:39 PM
Is the connection marked in white blocked off ? is your regulator set up properly ? is the fuel pressure rising when the boost comes in ?
Phil.
Phil.
Posted 08 April 2005 - 02:37 PM
ive told the engine builder bout the anti run on so lets hope its that, ive got so still to do before the l2b.
Posted 08 April 2005 - 02:39 PM
migla arches being fitted and blended!
