Point 1...
The GT NEVER had an 11 Stud head as standard
It was only the Austin 1300GT (and similar AD016 varients) and the Cooper S which ever had an 11 stud head...
Point 2
The GT is a solid walled block, does not have tappet chests, the Cooper S was the only big bore engine with Tappet Chests...
Point 3
If fact, @ GT externally looks like any other A series big bore motor ( even if it came out of an allegro ), and to be honest is not that different internally either... I'm not even sure the GT had double springs. But it did have duplex chain, not like you're going to see that from the outside...
if it's actually an A series bock then you at least have a chance that it's original.... if it's A+ then forget it...
Are the pushrods a lil different from "standard" blocks?? i mean how they look like...they are longer than 998's, but how about the shape???
i dont think they have double springs, but they have a duplex chain. (found it out on my head).
i recently bought a Rod 1275 GT ( i hope it is) block, but i saw the shape of the pushrods was a lil different from others.
are they any other points i can find out its a real 1275GT block???
the engine number plate is missing...i think the number must be 12H 706. neg.earth, alternator, mech, fuel pump,.
is this correct???
friendly regards, Fozz.
