Straight Cut Box, 5 Or 4 Speed?
22 replies to this topic
#1 haz
haz
  • 568 posts
Posted 07 February 2008 - 12:53 PM
Ayt people, I'd like to know your thoughts on straight cut 5 speed boxes
I've seen the minispares SC 5spd box, and looked at various 4 speeds, inc JK and the 'Mutts' from guessworks among others
My main concerns are, are they as reliable.. do i have to change anything else to fit one? appart from the 'H' ofcourse. And, are they worth it for pretty much an extra 1k?! :)
The box will be going on a 1380 - circa 100bhp at the fly
#2 Baldspeed Racing
Baldspeed Racing
  • 1,195 posts
Posted 07 February 2008 - 12:55 PM
ive got a 4 speed box which is more than fine for road and track use on my 1380 running 115bhp at the wheels. I do think a 5th gear would be nice for motorways tho imo
#3 haz
haz
  • 568 posts
Posted 07 February 2008 - 01:00 PM
whats ur FD ratio and top speed??
115 at the wheels, v.nice! what cam u running?
#4 [email protected]
[email protected]
    Minispares
  • Minispares
  • 3,231 posts
  • Name: Simon Jackson
Posted 07 February 2008 - 01:08 PM
Have a look at this
http://www.guess-wor...arbox/ratio.htm
Put in your tyre size etc, then which gear kit you plan to run, and you can calculate speeds in each gear, very useful!
#5 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 07 February 2008 - 01:18 PM
Thanks Simon, wasn't expecting that :)
what I would say tho, if you do loko at a 5 speed, you don't want to end up with too much overdrive in 5th, as then it'll become a wasted gear as you'll not be able to accelerate in it...
So treat a 5 speed as trying to fit an extra ratio in which the 4 use to cover.... ie a 4 speed has a final ratio of 1:1 in the box and then the diff factor, say 3.4 for arguments sake... If the final drive in a sc 5 speed is ( looked on MS site ) is 0.865 then ideally you want to adjust the final drive so the end result is the same as the 3.4 with a 1:1... does math in head so something like a 3.9 would achieve that result ( also reduce stress on the case and gears )
Simon, do you have to hand the ratios for your 5 speeds ( helical and SC ) and I'll see about adding them to the calculator...
Edited by GuessWorks.co.uk, 07 February 2008 - 01:20 PM.
#6 Baldspeed Racing
Baldspeed Racing
  • 1,195 posts
Posted 07 February 2008 - 01:34 PM
er I think a kent 286 rings a bell, been a while since ive talked specs
#7 GraemeC
GraemeC
  • 7,440 posts
Posted 07 February 2008 - 01:55 PM
Guessworks - if you do it that way then you would see no advantage on the motorway would you - you'd just be swappping cogs more often to achieve the same top speed at the same revs?
#8 [email protected]
[email protected]
    Minispares
  • Minispares
  • 3,231 posts
Posted 07 February 2008 - 02:19 PM
The advantage is you would still have the acceleration ability of a 3.4 for example, but the cruising ability of a 3.1.
#9 samwell
samwell
  • 1,520 posts
  • Local Club: SC Spammers
Posted 07 February 2008 - 02:20 PM
an get more accelleration in each gear. I dont think anyone who spends 2k on a 5speed box woud prefer a slightly lower rpm on motorways in exchange for better acceleration
#10 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 07 February 2008 - 02:30 PM
This is true... but assumption is, based on the fact it's a SC requirement, the intention is to 'give it some beans'.... and I would be warey of that with a long final drive and an overdrive gear...
We all know what a long final drive does to MPi gearboxes...
However, if it were a cruiser for the motorway, then yes make use of the extra legs provided by the overdrive.... but would you want a SCCR gearbox for that ???
#11 GraemeC
GraemeC
  • 7,440 posts
Posted 07 February 2008 - 02:38 PM
Not if you adjust the final drive of the diff as GW suggests. You'd get the accelleration of a 3.9 with the cruising of a 3.4(ish) assuming the first 4 gears in your kit are standardish ratios.
Beg to differ, but its not a factual point. I believe most people buying a 5 speed will be doing so for better cruising (and for bar points). If people just want hard accelleration then they'd change the diff ratio alone.
#12 GraemeC
GraemeC
  • 7,440 posts
Posted 07 February 2008 - 02:41 PM
True GW - I was missing the point that this was SCCR.
In which case I would say 5 speed is again bar points. A car that warrants SCCR is usually powerful enough to accellerate pretty handily in the existing 4 gears without needing a 5th ratio. I would much prefer to stay in a gears longer than change an additional time. But yes that would be more stressful on the box.
Edited by GraemeC, 07 February 2008 - 02:41 PM.
#13 [email protected]
[email protected]
    Minispares
  • Minispares
  • 3,231 posts
Posted 07 February 2008 - 02:43 PM
The boxes we supply come with a 3.4 diff, hence my example albeit for a helical kit. S/C would give more like 2.98
#14 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 07 February 2008 - 02:55 PM
Just incase you're wondering what "The Mutts" is....
[attachment=49774:07022008344.jpg]
#15 samwell
samwell
  • 1,520 posts
Posted 07 February 2008 - 03:02 PM
brilliant for acceleration if you have a ludicrously wide power/torque band such as a turbo but most engines tend to have fairly compact power band so more gears means better acceleration
