How does one decide which needle for 998 stage one or again which is best for 1275 stage one ?
I've seen AAA needles suggested for 998s but this needle was original equiptment for a two inch carb with the same size jet as a hiff 38 so how would that work ?
Is the profile so different or is it just thinner all the way up ?
BDL is another one that has been suggested but that is from a hiff 44 with a bigger jet. Not all hiff 44s have a bigger jet so, again, how can one needle be best for both size jets. ?
You can have two identical carbs both with different jets requiring different needles so it's not that easy to state which is best.
AAU is as fitted to an early 1500cc MGB and BDK is as fitted to early Volvo engines with hiff44 and jetted at 0.100" so a lot of fuel passing by that needle or very little if put into a hiff38 or HS4.
I've swapped and tried hundreds of needles in the past and hardly ever looked at the code on them, I usually run the needle between my thumb and forefinger to get an idea of the profile before adjusting with some fine wet and dry. Some needles are thick all the way down and some tapered to a fine point, thick is best for experimenting with if doctoring it.
There are hundreds of different codes for needle profiles but only three jet sizes, Hiff 38 and HS4 are usually 0.09" and hiff44 are in the main 0.09" or 0.100" but it depends on what the carb came off originally.
So how to decide on a code for your car? anyone know ?
