My New Dash...
36 replies to this topic
#16 Coleman
Coleman
  • 202 posts
Posted 10 February 2008 - 02:00 AM
your dash pretty much looks like the sex.
THE sex.
My opinion: i go with you, i much preffer them in a strait line.
#17 Pie
Pie
  • 7,695 posts
  • Local Club: GoGoAuto
Posted 10 February 2008 - 03:13 AM
why not;
"Austin
Mini"
?? Also i think a glovebox would probably look better than the fire extinguiser.
#18 langers2k
langers2k
  • 419 posts
Posted 10 February 2008 - 11:42 AM
Much photoshopping later I have produced a range of styles that would be possible.
The black bit is not a glovebox, but it will look like one closed, it will just be a piece of wood screwed to the front of the dash covered in black vinyl... Tell me which ones you guys think look good!
#19 Joshmini
Joshmini
    I Want To Ride My Bicycle! (Just Not Peddle)
  • 1,534 posts
  • Local Club: MSN: Josh_howie@hotmail.com
Posted 10 February 2008 - 01:02 PM
The gauges will look beter like the one in your picture
#20 Pie
Pie
  • 7,695 posts
Posted 10 February 2008 - 01:06 PM
Top picture. The black breaks up the dash more.
#21 langers2k
langers2k
  • 419 posts
Posted 10 February 2008 - 01:28 PM
Which gauges and which picture... Don't quite get what your trying to say? Sorry :P
Girlfriend also like the top one, I think I need more wood!
#22 Pie
Pie
  • 7,695 posts
Posted 10 February 2008 - 02:30 PM
Which gauges and which picture... Don't quite get what your trying to say? Sorry >_<
I didnt get that either
LMAO anyone else find that amusing :P
#23 jonny d
jonny d
  • 1,148 posts
Posted 10 February 2008 - 03:01 PM
I did
#24 langers2k
langers2k
  • 419 posts
Posted 10 February 2008 - 08:12 PM
Heh I did too :)
Taken some wire to it today, after 10 meters worth (god only knows where it all went) I have something that resembled this:
Still need to add a connector to the end, sort out the car side of things and get some LED bulbs as the standard ones are soooo dim! Just because I could I plugged it in and turned the lights out, main dials were so dim my camera couldn't pick them up, but as for the aux ones, take a look...
#25 mike49
mike49
  • 973 posts
Posted 10 February 2008 - 08:29 PM
that top image with the black cut out and slanted lettering looks top! id personally go for rounding off the edges of the clock surround but top job all the same
#26 Black.Ghost
Black.Ghost
    Formerly known as TneMini.
  • 2,567 posts
Posted 10 February 2008 - 11:55 PM
That looks really good. Id be really pleased if I could produce something like that.
The back looks complicated!
I think all the designs look pretty good to be honest.
Nice work
#27 langers2k
langers2k
  • 419 posts
Posted 11 February 2008 - 10:30 AM
Nice work
Get some MDF and have ago! If you not sure how to make something, try it in cardboard first... Oh and measure twice, then cut once :ermm:
The back isn't that hard, I started and the end with the aux gauges on and worked across to the rev counter. Use a multimeter to check the connections when your done and make sure you label what things are! Different coloured wires would make things easier but I only had black. If you don't try you will never know if you can do it =]
If it all goes to pot, just use your original dash until it looks like you want it to. There are plenty of people who sell plain dashes on ebay so you could get one and try making one around that.
#28 langers2k
langers2k
  • 419 posts
Posted 11 February 2008 - 04:56 PM
Its in! And its all works, the voltage readings are well off so I may need to check the voltage supplied to the dash in comparison to the alt/battery but everything else seems good. It even has its own quirks already, the tacho came from ebay and when I start the engine it doesn't give a RPM, but if you wait a 5 seconds or blip the throttle it starts working perfectly...?
#29 ImagoX
ImagoX
  • 259 posts
  • Local Club: MidOhioMotoring.com
Posted 11 February 2008 - 05:23 PM
Tell me more about the harness that controls all these gauges... Is it a home-built system, or did you purchase it? I like the extra gauges, but I'm not sure how you're controlling them all through that harness...
#30 langers2k
langers2k
  • 419 posts
Posted 11 February 2008 - 06:14 PM
The harness is all home built, on the other side of the terminal blocks there is a stereo ISO plug which connects the dash to the car loom (which has also been modified).
The vacuum gauge is mechanical so it gets power/ground/illumination, the voltage gauge again needs power/ground/illumination and finally the oil pressure gauge needs power/ground/illumination/pressure, so really the pressure is the only one that needs controlling via an electric signal, you can see the wire as its the only green wire on the dash. This connects through the ISO plug to a sender in the engine bay.
I have tried to make a circuit diagram below showing where all the wires go. It might explain how the electric side of things work. I have removed the mini pcb from the clocks and then soldered/crimped to the fuel/temp/tacho and the bulbs.
