Painting Subframe
7 replies to this topic
#1 shashora
shashora
  • 202 posts
Posted 10 February 2008 - 09:36 AM
Hey just plan on painting my subframe on my day off tomorrow and i have a spray gun and aircompressor that i havent used yet. I was scared id screw it up on the body so im just going to do the subframes.
From what ive read in the forums hammerite is what i should spray the subframe with, is this right?? Because ive got some plain matte black paint that i bought a while ago from a auto paint shop, that i wouldnt mind using....
I am goign to just sand it back and respray..
Just wondering thoguh, if i do take the subframe back with sand paper and theres no rust can i just spray from there or do i need to put primer on??
Also if i do take it back theres rust so i take it back to bare metal, do i then spray dioxidizer then with etch primer then primer then with a couple of coats of watever paint im using??
Sorry i know im a newb just dont want to stuff it up and put the subframe in and have rust a month later.. :thumbsup:
#2 bakker110
bakker110
  • 426 posts
Posted 10 February 2008 - 09:49 AM
I've just sprayed my subframe with hammerite, i did have it shotblasted first but only because it was filty. I sprayed it from bare metal and its fine. Hammerite doesn't really need a primer.
I'm no paint guy so don't take my word but mine look fine (read the tin on hammerite too) and i doubt they'll rust anytime soon.
#3 England_expects
England_expects
  • 120 posts
  • Local Club: A-Serious & BOGMOG
Posted 10 February 2008 - 10:25 AM
If you are going to use the black auto paint, I'd recommend shotblasting and etch primer if you are looking for decent longevity and a good shine.
I used to use Hammerite, painted over a degreased subframe which usually gave good results and is pretty hardwearing. Don't know if there's a better alternative since though?
#4 morley
morley
  • 903 posts
Posted 10 February 2008 - 10:49 AM
I'm gonna be paitning my front subframe aswell soon, i'm gonna give it a few coats with red oxide paint and then some black hamerite hopefully it'll last alot longer!
#5 mk1leg
mk1leg
  • 9,343 posts
Posted 10 February 2008 - 08:37 PM
Hi..I had mine sandblasted and I used redoxide and grey primer and a black high gloss finish..................
#6 shashora
shashora
  • 202 posts
Posted 10 February 2008 - 10:28 PM
Wow lookin good guys!
I also just found a thread if anyone else wanting to spray the subframe needs a hand :)
http://www.mpdesign....ng/painting.htm
scroll down and there is a part on subframe
#7 shashora
shashora
  • 202 posts
Posted 11 February 2008 - 01:09 AM
Ok final question...
If i spray the subframe with my black matte paint i already have
I take it back then use dioxidiser on it
then i spray with primer then i
can spray paint...>? is that correct
And final final lol
when mixing do i need to mix dioxidiser with anything?
Also for paint and primer how much do i have to mix with thinners and how do u know??
Really appreciate your guys help : )
#8 Scott.Tamson
Scott.Tamson
  • 750 posts
  • Local Club: None..on here alottt though :)
Posted 11 February 2008 - 01:33 PM
Quick question needing answerd, as ive got my back subby out the now and its a good day, should i take it back to bare metal before painting ??.
Scott
