for some reason my mini has developed a misfire and i cant work it out the problem. it occurs in the top end of 4000rpm ,more like 5000. also the popping is more noticable at higher speeds or if the wind is against me- 1st gear isnt so bad, 2 is worse, 3 is even worse etc..
up to 4700-5000 she revs clean and smoothly- luuuverly...
i have checked the jets in the weber- all clear.
plugs, leads, coil, dizzy and eleccy ignition is all new.
earths are fine.
the fuel pump is a big SU double sided electonic one, so i doubt its fuel related.
no luck on the search either
so i am thinking its either the coil, (doubt it but i have a spare lucas gold that i havent tried on yet so i dont mind it that could be the prob) or its the petronix leccy ignition as apparently they suck anyway (its my second one as first was faulty and steve from MED said they were C**p too)
anyway ideas guys? its started to really bug me as its so annoying driving within such a tiny power band (3K- to just under 5!!)
