Should i have it sprayed in etching primer or a red oxide based paint bearing in mind that i will need to do filler work on top of the primer after the shell has been shot blasted.
Many Thanks
Phil
Edited by philly c, 19 February 2008 - 07:36 PM.
Posted 19 February 2008 - 07:35 PM
Posted 19 February 2008 - 07:44 PM
Posted 19 February 2008 - 07:55 PM
Posted 19 February 2008 - 08:00 PM
so a good etching primer after shot blasting should do the trick hey?Guess it just a loat of hard work with the filler next then? and cutting and grinding relative areas but ensuring that the welded aras are then primered agina when necessary?
Phil
Posted 19 February 2008 - 08:54 PM
Posted 19 February 2008 - 09:27 PM
